According to Catalina Direct the varnish used to finish down below in a 2005 is/was: Varnish, Semi-Gloss Interior 2001-2007. I am assuming this semi-gloss was used on bulkheads and flooring. The cabinetry, cabin ladder, tables appear to be have a higher gloss finish. Any info on this?
Thanks.
Dave & Nancy Warren
"Blue Heron"
Norwalk Cove Marina, CT
2005 C-36 Mk II #2256
'Anniversary Edition'
Wing M35B
I believe I read somewhere that it is a water-based varnish also...
I recall seeing something on Catalina Direct in the past year or two that claimed to be the originally sourced varnish used by the Catalina factory. I believe they had certain finishes that were tied to certain model years.
Check the bottom of this page: http://www.catalinadirect.com/index.cfm/category/795/interior.cfm
You may want to start there.
Matt
Matthew Becherer
s/v Constellation
Catalina 36 MKII, #2104
Wing Keel, Standard Rig, Universal M-35BC
