Replacing Furler - suggestions?
BrentF's picture
BrentF
i took advantage of Hood's upgrade program to replace my old balky single line  one continuous loop furler with a new unit,  Any suggestions on disassembly, securing the mast, etc or other advice?
thanks in advance
Brent and Janie Farler
"Salsa Caliente"
1987 Catalina 36 Hull #719
Lake Texoma, TX
If your just replacing the drum unit the mast will stand by its self. But to make you feel safer. Take and use your jib halyard and fasten it to your forward bow cleat and put a little bit of tension on the line.
BrentF's picture
BrentF
Thanks Randy, your experience is highly respected.
Replacing whole furler - Line, Drum, extrusion and top swivel.  Hopefully no forestay components need replacing (freshwater).
"Salsa Caliente"
Lake Texoma, TX
raptor
Hope you do not mind if I hijack this post - I have an balky continuous-loop furler (original Hood from what I can tell).   I was going to replace with a single line, but this post makes me think I might be better off fixing what I have - it needs a top-roller cap and a new line.  Any thoughts? I do use the reefing capability of the continuous-loop - I have seen that single-line furlers are not designed for reefing - is that the case?
Suggestions welcome! Thanks!
Aaron
Aaron
Guilford, CT
1988 Catalina 36 "Raptor"
Aaron,
Here is the link to the upgrade. It was just for the bottom section
https://www.pompanette.com/BigSummit/pomp.nsf/Products_lookup/83C989D433...
I replaced mine several years ago when the continuous  line when furled and cleated would unfurl.in heavy wind. I suspect you can get additional parts as I believe they are now manufacturing in NH @ Pompanette
BrentF's picture
BrentF
I upgraded to the Searfurl 808SL.  It came with all pieces lower unit, extrusions and upper bearing.  Was about 40% less than without the upgrade.
"Salsa Caliente"
Lake Texoma, TX
Floris van Bentum
Has anyone got a suggestion as how to replace the drum on my older Hood furling system fitted on my 1992 Catalina 36 and where to order a new one in Europe/the Neterhlands? It's about 30 years old and works relatively well, but not well enough that I trust it enough in windy conditions.
Kind regards,
Floris van Bentum
Floris;
 You might try sending these folks in Tampa, Florida and email and ask for the name of the current parts distributor in Europe. They are usually very helpful. Questions to Corporate hedadquarters in New Hampshire on Hood products directs you to Tampa. Use the ​hoodyachtsystems@pompanette.com address.
Contact Information
HOOD Yacht Systems
7712 Cheri Court
Tampa
FL 323634
USA
TEL: 813 885 2182
FAX: 813 888 5793
POMPANETTE, LLC
Corporate Headquarters
South West Street
P.O. Box W. Charlestown
New Hampshire USA 03603
TEL: 603 826 5791
FAX: 603 826 4125
Electronic mail
General Information: hoodyachtsystems@pompanette.com
Customer Support: pompanette@pompanette.com
