Electro Scan Installation
Katy-did
I am considering installing an Electra Scan in my '93 Cat 36 (it has a MkII cabin lay out)in the location where the holding tank currently resides (under the port setee). Does anyone have plans for positioning the device or advice on installing it?  I believe that the vertical placement is critical?
Alex
SV Scarlett
William Miller
I love my electro scan and so does my wife.It is easy to install. We put in a smaller holding tank and put the unit to the left side of the holding tank so you still have a holding tank if need be .You will find that if you are in some marinas the water is not salty enough so you just throw in a hand full of solar salt .The number one thing to do is the maintenance once a year you mix 3 pts muraic acid to 1 gallon of fresh water ,run thru head and let set for 45 mins ,put 10 gal of salt water thru and good to go. No more pump outs/I have three friends who have the system and they like it.The surveor said people love or hate these, we love it
