M35BC Just passed 3000 hours!
knotdoneyet
Passed it on my trip to the Dry Tortugas.  2250 seems to be a good RPM for mine and judging by my fuel records, I appear to burn around .65 GPH.
There always seems to be questions about how many hours your get out of a diesel.  This one still runs great.
2000 C36 MKII 1825
That makes two of us. Photo from a few days ago...
I just broke 1000 two weeks ago...
I'm guessing that you have a three blade prop?
I have the stock two-blade, and have no interest in re-propping.
This brings up a curious question (in my mind)  regarding tachometers and their integral clocks. In my other 'OFF ROAD' vehicle, A Cessna 206, the clock in the tachometer reads only full hourly time when the engine is operating at full RPM. If the engine is running at any thing less than full RPM, the clock in the tach. will not record full hourly time.That is to say, if you sit there at idle in the plane for four hours, the clock in your tachometer will not record four hours, rather something much, much less.
There is also a HOBBS meter in the plane  that records actual clock time; a full minute for every minute there is oil pressure.
I'll have to measure whether tach. clock in the c-36 records actual time or a percentage there of.
Does anyone know ?
We're producing 5.6 knots at 2250 RPM with a three blade prop and consuming .56 gallons per hour (average)
1990 C-36 #1041, , SR,WK,WT, M35,
Port Charlotte, FL.
gforaker's picture
gforaker
Bill,
The hour meter in our boats measures time the key is on.   I almost never run at WOT and it seems to be accurate.
[quote=Catboat Willy]This brings up a curious question (in my mind)  regarding tachometers and their integral clocks. In my other 'OFF ROAD' vehicle, A Cessna 206, the clock in the tachometer reads only full hourly time when the engine is operating at full RPM. If the engine is running at any thing less than full RPM, the clock in the tach. will not record full hourly time.That is to say, if you sit there at idle in the plane for four hours, the clock in your tachometer will not record four hours, rather something much, much less.
Does anyone know ?
Port Charlotte, FL.
 [/quote]
Gene Foraker
Sandusky Yacht Club
Sandusky, OH
1999  C36  #1786
Gypsy Wagon
knotdoneyet
3 Blade prop and just had the hull repainted to the boat is moving very well.  I was getting around 6.5 knots on 2250 for the trip.  7.2-7.5 knots motor sailing with a light wind.  All GPS SOG.
Enjoying it while the paint is fresh.  :)
Note that I have not validated my tach so take with a grain of salt.
2000 C36 MKII 1825
