Mercury 3.5hp Convert Long Shaft to Short Shaft
After a 6-hour run yesterday getting my dinghy from home to the mother ship, I'm of the belief that I need to convert my new long shaft Mercury 3.5 (a new 4-cycle) to short shaft. As it is, the O/B extends nearly 16 inches below the dinghy keel, and that will seriously limit my ability to get ashore in the Pacific Northwest's rocky shoreline and to have access to some shallow waterways.
Has anyone done a conversion like this?
Larry,
I don't have a conversion kit, but I agree completely with your desire to convert to a short shaft.  Everything I have read says that you should NOT use a long shaft OB on an inflatable or any other small dinghy-type craft.  The torque/stress on the transom is too great, even with a relatively low HP OB.
Larry;
 Several years back we tried the conversion the other way around, that is from a short shaft to a long shaft. In the end, the cost of parts was far more than anticipated and it would have been cheaper to just scrap the engine. It was only two years old. You will most likely find that you will need special internal parts (shafts etc)
My response to your question would be; Try and sell it as is and don't mess with an attempted with conversion. Use the proceeds from the sale to get yourself a newer short shaft engine.
Bill Dolan
C-36 # 1041
Larry...
 I'm guessing, but I think if you did try the conversion you might invalidate any warranty you might have on your new long shaft. I agree with the comment about just selling it and going with a short shaft.
cussy's picture
cussy
Hi Larry   We had the same problem as you  and same engine , we bought a used engine that had been ran dry of oil so power head was gone and swapped everything below the head it took me around 45 minutes to change over you would not believe how easy it is to do , the ruined engine cost me £55 as it would have cost the lad i bought it off a small fortune to repair it , I made mine short shaft and ( being a scotsman) put everything else on ebay and yes made a nice little profit , I did keep the coil , carb ect for spare parts
cheers Kenny
Geileis
Hull 1489
1995
Fin Keel
U shape Lounge
Westerbeke M35 engine
Mikuni heating
Second best thing that ever happened to me
