Hi hope some one can point me in the right direction ,I have just bought a 1995 c36mk11,the thermostat in the lounge above lounge seating got wet and blown,who would i contact to get a replacement i live in the UK but willing to pay shipping as our winter is coming ,
Also is it possible to buy a complete rig( ours was the tall rig) complete with sails, lines ,everything from deck up ready to fit our mast snapped at sea and rescue services said they had to be cut any advise would be great thanks
Geileis
Hull 1489
1995
Fin Keel
U shape Lounge
Westerbeke M35 engine
Mikuni heating
Second best thing that ever happened to me
Wow. What caused the mast to come down? Good luck in finding the rigging.
Duncan McNeill
1984 Catalina 36 #178
standard rig fin keel M25
Channel Islands
Cussy,
What thermostat are you referring to? The only OEM thermostats I know about on the C36 are the one in the engine, and the one in the fridge. If you are talking about a thermostat which controls some type of heating system, it was installed by the PO, and not Catalina. Need more info. Sorry.
Cussy... are you talking about the control switch for a heating/ A/C unit? I have that above my nav table on my 2002. Its an after market item. I should be at the boat today & will look for a name. If its not a Heat/ A/C control panel, I'm with Tom... what thermostat is it.
Cheers Chuck yep that's it , great thanks if you could also can't find the make of the mast have various companies over here in uk wanting to make me one but trying to get original maker is your mast seldon been told that is who supplied them originally cheers again
Geileis
Hull 1489
1995
Fin Keel
U shape Lounge
Mikuni heating
Thanks Tom yes it's the heating control for tha cabins lounge ect I thought they were fitted in manufacture cheers
Geileis
Hull 1489
1995
Fin Keel
U shape Lounge
Mikuni heating
Cussy... my heating / a/c came with the boat so I suppose it was installed by Catalina or a subcontractor they hired though I bought the boat when it was 2 years old so the PO my have had it installed. The unit itself is a Cruiseair and the control unit in the cabin is an SMXir. SMX seems to be the company making the control units but I could not find an address on anything I have. Cruiseair is in Virginia and their phone number is 804-746-1313. I'm sure the could give you more info on SMX (SMX seems to make more than the SMXir units).
As far as the rig, I have a US Spars mast furling rig. I do know Catalina does not use the same vendor on all boats however as I have seen Selden booms on similar model boats. I assume Selden makes the masts too but that is an assumption, always dangerous.
Hopes this helps.
Thanks alot chuck yes found it through cruiseair been trying everywhere with no luck , and for the mast yes US Spars could not be more helpfull again thanks ,made a scotsman very happy and a scotsmans wife nice and warm cheers
Geileis
Hull 1489
1995
Fin Keel
U shape Lounge
Mikuni heating
