I posted this issue on the Raymarine Forum with no solution offered yet. The unit had been working fine until I decided to adjust the contrast. I think I followed the instructions correctly as the contrast was fixed but immediately after, the unit went into a cycle mode of between 10ft and about 25ft and whether or not the transducer is connected. I think this is a dealer mode but the manual has no instructions on how to activate or de-activate this mode. Any advice, solutions? thanks.
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Is there a factory default setting which returns everything to original?
Gary. No reference in the manual on how to return settings to factory settings. I have tried calling Raymarine but the wait time on hold is beyond my endurance threshold. Will keep trying at different times of day.
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
My previous answer is not quite accurate. The manual indicates what the factory settings are but changing the individual settings to those values does not fix the problem. There is no instruction on what key or combination of keys to push to accomplish a system return to factory settings as is the case with other instruments.
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Alain,
I found my old Autohelm Manual ST50 here is a page from it that may help.
Gary
gary. the pdf down load keeps failing on my tablet as well as on a friends pc. we get 'certificate warning' type of pop up warning. we are at our boat now. can you send it via email to alainfcroteau@yahoo.ca plse. hopefully that will work. thks!
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Gary: I was able to view and print the pdf on my home laptop - thank you. We are back at the boat on Friday. I'll use the instructions provided and give you an update. Strange that the set of instructions you sent me are not part of my ST50 manual.
Alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Alsin,
When I bought the ST50 it was not Raytheon but Autohelm I have had the unit many years and it is sitting in my garage spare parts bin.I'm just offering as a help as it was the way to set the depth sounder.
No worries Gary. Appreciate your help. Will try it tomorrow. I'm assuming I'll get a chance to try the fix. We're bringing a 3yr old grandson and a 16 month old granddaughter out with us for a couple of days and they demand attention....maybe during nap time...if they nap.!? Alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Well, good luck and enjoy the grandchildren.
Gary
Gary: the couple of days with the grandkids was successful and most enjoyable but the fix was not. Was worth a try. I also finally got a response from Raymarine. Their assessment is that it is a 'processor PCB' failure and can't be fixed so looks like I'll be shopping for a new sounder. Am looking into an ST60 as it appears it may be compatible with the existing transducer. (looking for confirmation of this). If yes, will connect for balance of summer and install new thruhull transducer at haulout this Fall. BTW, my unit is Autohelm and not Raytheon....not sure where/how I came up with Raytheon???!) thanks again for your help. Alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Alain,
I have the ST 50 instrument, cover, manual, etc. no transducer. These came off the Catalina 30 I owned. It still worked when removed. Any interest? Not sure what it would cost to ship, but it is yours for that price.
Gary
Gary - that would be worth a try and if it works i'll add $50 (don't get to excited as it'll be canadian funds!!?) I have stuff to pick up in Ogdensburg NY so if you can send via ups to: UPS Store attn: Alain Croteau 2981 Ford St Ogdensburg NY 13669 ph 315 393 1188 that would be grand and much appreciated.
Alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Alain,
Try to ship it today looking for a box. I actually have transducer as well and when I got everything together, it dawned on me it came off my 36' Cat. I had the knot meter as well but that had an issue so I did not keep the KM. Also explains to me why the manual is in the condition it is. Anyway you should have it shortly.
Gary
On it's way......
UPS 1ZR11V700393970467 (came to $21.18) said it would be there Thursday July 17.
Thanks Gary.I'll be heading to ogdensburg in the next couPle of days then on to the boat for a 8 day cruise. Will have the opportunity to install and test the unit then.. In the meantime, i'll require your mailing address please. alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Gary. Unit works fine. We're on a bit of a cruise. Will take care of business on our return early next week. Thanks again! Alain
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
Glad to hear all is well, enjoy your cruise!
