Macreator pump Do I need it?
lflenner
Hi Everyone,
I had a bad smell I couldn't track down until this weekend. I found that the bolts holding the macerator pump together were coroded  and brken off so sewage was leaking out the bolt holes. I looked on Westmarine and this seems to be a very common complaint with the jabsco pumps with some people saying they didn't even last a season. I'm on the Chesapeake and have a pump out at the Marina. I never use macerator pump. Is there any reason to have it if so many people say they are junk or can I bypass the hole thing and connect the deck pump out directly to the tank?
Thanks for any insite.
Larry Flenner
"Low Pressure"
C36 MK II 1995 TR/WK
Rock Hall,Md
Capt. Sam's picture
Capt. Sam
My used 1994 C36 came with a Jabsco macerator installed. I've had the boat for three years with no issues, all of my overnight cruises take me outside the limit for discharging overboard on the Gulf of Mexico, so I use my macerator fairly frequently and almost never need to pump out at the marina. I have both the deck connection to pump out  using the marina's vacuume system or I can use my macerator when outside the limit. I much prefer the macerator. Its so much easier and more sanitary. I wouldn't be without it. If you spend almost all of your nights aboard at a pumpout equipped marina, you could do without a macerator. But I wouldn't. Your boat, your choice as they say.
Sam
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
jhenderson
I would consider resale value also. It's never wise to part with standard equipment.
Hummina
1987 Catalina 36 MKI
#741
Bayfield, WI. Usually.
Wavelength's picture
Wavelength
The first time your tank is full and you are now where near a pump out and the admiral needs to use the facilities...... you will wish you had that macerator. Always expect the unexpected.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
In 39 years I only purchased 3 jabso macerator pumps for the reasons you stated, but do not believe that is very bad?
