Hi everyone,
I'm a new owner of a 2002 C36 MKII with a universal m35b engine. I've previously owned yanmar engines and this is my first universal and I'm having some issues that I can't figure out and need some help understanding what are the potential issues that could be causing these issues.
A bit of background, the boat has been sitting unused on the hard with a full tank of diesel for about 20 months. It has 545 hours on it and looks in great shape, no rust etc, evident leaks etc.
Before launching I changed fuel filters and found no water and no sediment, filters clean. These are the issues.
1. Vibration. The engine vibrates a lot on IDLE in NEUTRAL. the vibration shakes the entire cockpit. Vibration goes away at above 1200 RPM. The engine idles at 875RPM, tachometer and check by handheld tach.
-I check motor mounts and all look OK, no loose bolts, nuts. Rubber looks in good shape, no rust, black dust etc.
- Engine runs very smooth at any RPM above 1200, in neutral and gear, no vibration at all. I get full RPM in neutral and gear. I motored for 2 hours in no wind and engine temp was 160 or so, no issues at all.
I am lost at what else to look at. Since it is in neutral, and no vibration at all above 1200, I am assuming it is not an alignment issue, am I correct? What else could it be? Is lots of vibration normal in this engine in idle and neutral? (Maybe it is normal)
2. The engine is noisey, almost like it has an issue with the silencer. Is this normal? Maybe my expectation of a low noise 4 cyl is off.
3. The engine produces a smell in the cabin. No smoke at all, just a mild, though bothersome, burnt oil or something similar after a few minutes of using it. I pulled the silencer(?)/ air filter and cleaned it with a solvent, found a bit of oil in the metal element inside, cleaned and reattached, no real help.I see no leaks in the exhaust system.
Any suggestion of what to do next for this issues (if any)?
Thanks a lot for reading this long post and any help.
-Abrahan
Sailing from Norwalk, CT
2002 C36 MKII, "Cataluna", Hull#2077
My M35B vibrates quite a bit up to about 1200 too, then smooth as silk. I've actually reduced the idle speed a bit, so now there's just a range I avoid. My suspicions are (A) normal for this engine, (B) aging mounts, (C) uneven load on the engine mounts, i.e., when the alignment was done there was not enough attention paid to trying to keep even weight on each mount.
Insofar as noisy, my engine is like all diesels, rattles quite a bit, but not an abnormal amount. Low fuel quality might be an issue and might be a contributor to some of your vibration too.
Lastly the smell. These engines are sealed well, but check to make sure the crankcase breather is routed either overboard, or more commonly directed to close proximity to the intake filter.
Hi Abraham,
This sounds very much like a damper plate issue to me:
[url]http://www.foleyengines.com/resources/tech-tips/zfhurth-and-borgwarner-d...
These are noisy in neutral or low rpm, and usually the noise goes away at higher rpm. I had a similar issue recently (for me, most noticeable at low rpm in gear), and replacement of the damper plate really helped a lot (my engine hours were right around where yours is).
The smell would be a totally different issue, most likely. You shouldn't have anything like a serious exhaust smell in the boat at any time under any conditions, so i'd look pretty carefully for any loose hoses/fittings in that regard (especially check that the riser is well bolted on). Carbon monoxide is a killer, so I'd put your smoke/CO detector in your aft quarterberth while the engine is running, just to be sure you're not getting a CO leak.
Josh McElwee
As Nick mentioned, I'd be suspicious of that old fuel. Diesels are compression ignition, it's a bit hit and miss at the best of times, compared to spark ignition, and having old fuel will make that much worse. Plus it will coat your fuel tank with all kinds of precipitates coming out of the diesel. If it's off to the point that you're getting pre-detonation you will get all kinds of nasty side effects with the engine, it can drive cylinder head and bore temperatures way up beyond normal and will not likely show on the heat gauge that it's happening. I'd pump it out and put in fresh and see if that helps before spending a lot of money on other stuff.
Maybe a dumb question but what is the best way to drain the old diesel fuel out.
1996 C36 Mk II, #1545
Frankfort, MI
Thank you so much guys, this gives me lost to do, an gives me some baseline about what is normal in terms of vibration.
I spoke to Hansen Marine this morning and they think fuel (old fuel) could be the issue. They recommended to change the fuel completely, run it for a few hours and see what happens, if vibration issue continues, perhaps pull the injectors and test them.
Regarding alignment,will double check today.
Damper plate: Will definitely look into this, I was aware of this potential issue but looking at the symptoms I read on your link and the hurth transmission bulletin, sounds a bit different.
Final, will look into making sure all exhaust hoses are well attached and adjusted. Already put a CO detector in the aft cabin just in case, though something tells me it is not exhaust.
Thanks again and will report back.
-Abraham
Another thing to help get rid of smells is putting ing a closed crankcase vent system. I put in a Racor and it made a big difference
I believe your only options to remove the fuel are either pump or siphon it out you can access the tank behind the side panel in the back berth and remove the filler hose at the end of the tank. Another option would be hiring a fuel polishing firm to remove the fuel and haul it away for about $250. Any concern about the condition/contamination of the inside of the tank?
David S. Power
Two If By Sea #1687
Burnt Store Marina
I had the same question about removing the fuel. I did add BIOBOR (in the initial dose) and run the engine hard the past weekend. I am hoping to use half the tank and then put fresh diesel, less complicated than trying to empty it.
In addition I adjusted the valves and things are a lot better. Not sure which one of these have done most of the trick but there is an improvement.
About the smell. I did two things as suggested, adjusted all exhaust hoses (none seem to be lose, but nonetheless). cleaned the air filter/silencer again (teher was still some oil) and change teh hose from crackcase to the air filter (it had small ammount of oil). The small ammount of oil I am assuming is from pcv(sp?) system (exahust back to air intake). I think the smell I was getting was from that bit of oil sitting in the filter and hose getting hot.
-Abraham
Hi. One thing it might be is a crack in the exhaust riser. It's covered with fiberglass wrapping - hopefully not asbestos. (If it's asbestos, obviously replace it safely.) When you unwrap it, if you find a fine black soot, that will be probably be coming from the exhaust leak. Unwrapping makes the exhaust leak easier to find.
Ben Ethridge
1984 MK1 Hull# 263
I emptied my fuel tank using an electric oil change pump. You can dump the old fuel in any old oil recycle tank as its just more refined oil. Only problem is, a full tank will probably require about 10 trips to the fuel dump site using a typical oil change pump unless you can figure out how to drain it into a bigger cpacity container.
The pump costs about $125 -$150 at WM and if you don't have one already, I think its a worthwhile investment as you can use it to change oil, suck up any bad things besides water that get into the bilge, etc.
On a different topic,anyone find the spell check on the new site???
If you have a Windows machine, download iEspell. Works across the board on all websites.
Quick update, re: engine vibration in idle and neutral.
Not much improvement! My mechanich checked and fixed valve clearance and it looked like that helped, but I noticed that he also reduced the idle rpm to less than 700 ( measured by boat tach and IR tach). So no vibration when idling at 675rpm, then lots of vibration between 800 and 1000, and goes away at above 1100. Does this no vibration at that low rpm tell you something? I am confused.
Based on the manual and talking to other boat owners more mechanically inclined, I was told too low idle (below recommended) could have a detrimental effect on the engine, so I bumped it up backto 900.
Only thing I have not done yet is change the diesel, hoping, though not to optimistic, that it will help
Abraham,
I had a similar issue with vibration and fixed it by increasing my idle RPM to 1000. Universal recommends the M-35 have an idle RPM between 800-1000. See page 9 of the manual: http://www.westerbeke.com/OnlineManuals/200494_m320a_thru_m35b_operator_...
Ron St. Onge
C36 #1384
Ron St. Onge
1995 Catalina 36 MKII Hull 1384
Even though my engine idle is low, I do acknowledge that it's not good for prolonged operation. This is true for diesel idling in generall. Diesel engines are such that fuel flash points vs. piston position are imprecise, leading to vibration especialy in low inertia situations (idle). Hard to say if your vibration is off-the-charts. Did the guy who adjusted your valves give an opinion in this area? Fuel issues account for the vast majority of engine woes, so if the problem is real continue along this line. Also verify if the weight on your mounts is even, i.e., one mount not excessively compressed. This can easily happen during shaft alignment.
Thanks everyone who has helped me so far. After adding new diesel, adjusting the valves and aligning the engine/shaft, nothing really has worked.
Vibration between 800 and 1100 RPM in neutral is pretty bad (at this point I know the vibration is way above "normal", it is pretty strong)
From the suggestions above, the last thing that could be causing this vibration is bad motor mounts and although the mounts look in good shape and not bottomed out, I know that can be deceiving.
At this point I am going to look for a mechanic with experience in this engine and get an opinion.
I'm curious about the motor mounts as well, not the upper larger adjustable mounts, but the smaller ones that go into the fiberglass (and wood?) base. Are these thru-bolts or wood screws? Reason I ask is that I don't see a way to fully tighten them, since I can't see how to get at the lower nut (if it even exists).
If they are wood screws, then I think mine are starting to strip out of the wood and I'll need epoxy and re-drill new screw holes for them.
Anyone know?
See if yours has a lock washer just beneath the upper screw head. If the lock washers are not fully flattened, that is the telltale sign that the lower mounts are loose.
I'm thinking this could be causing your vibration now and mine someday.
Ben Ethridge
1984 MK1 Hull# 263
Ben,
The motor mounts are attached to the beds with lag bolts (roughly 2.5" long?)into a thin layer of fiberglass, with wood underneath. There should be a lower nut, motor flange, lock washer, and then an upper nut. If any are missing, you may have a problem!!
Ben and Tom, thanks for you suggestions.
Ben, do you mean the screws/bolts that attach the motor mounts to the engine bed? Those in my case can be adjusted with no problem. What do you mean by "lower mount"?
Tom, do you mean that the stud in the motor mount should have a lower nut, then the motor flange, then a washer and then an upper nut? In my case I have no washers in the mount stud (not sure if this is how it is called) hmmm...
Thanks again, I am going to keep trying your suggestions, while trying to find a competent/knowledgable mechanic in the area.
-Abraham
Yes, those are the ones I mean, i.e. the lag bolts Tom speaks of. Maybe I'm just missing something simple, but I don't yet see how to get at the lower nuts. This is an MK1.
Ben Ethridge
1984 MK1 Hull# 263
Ok thanks Ben. As far as I can tell there are no nuts on those bolts in the mkII
Abraham,
Perhaps this pic will help. These are not OEM mounts, but the concept is the same. These are softer Vetus K75's, so yours will not have the motor mount nut. Upper and lower adjusting nuts are tightened against each other, and with the lock washer, keep the engine in place. This engine is just about at the lower limit of adjustment in the pic. Normally the nuts and engine flange are roughly in the middle of the stud. Left/Right adjustment is done by moving the motor mount, after loosening the lag bolts. Up/Down adjustment is done with the adjusting nuts. Hope this helps.
Thanks Tom. Very helpful. I do have the original mounts on the M35B (with about 560 hours now). They do have an upper and lower nut, no washer in my case though and they are not bottom out at all (any of the 4). Teh picture attached is the forward port side mount, showing the motor flange right in the middle of teh stud (sorry for te hbad quality of the pic).
Still, I think my problem might be mounts.
What Tom shows in the picture is exactly my setup. One of my lag bolt heads was loose, so I tried to tighten it...but tighten it against what? There is no lower lockwasher/nut that I can see, and by definition, a lag bolt would not have a lower nut, i.e. it's just basically a wood screw, and it feels like it's starting to strip out.
I think that over time, the engine vibration wears away the wood(?) into which the lag bolt screws, and this is what I'm thinking could cause excess vibration (on MK1s at least).
Rebedding the lag bolts seems like it would be a major job to fix. Hopefully I'm missing something simple, coz this just seems like a poor design to me.
Ben Ethridge
1984 MK1 Hull# 263
Ben, the lag bolts are fairly easy to fix. There are several options, easiest is to line the hole with toothpicks smeared with epoxy. Sounds cheesy, but it works. You can pour in a penetrating epoxy and let it saturate the wood which will stabilize it. You can also fill the hole with thickened epoxy and drill it out. I hate to say it, but there have been several discussions about this issue on the forum.
Probably is poor design but most boats I've seen with inboard engines use lags into wood stringers, including the big honking stinkers with the massive V8s.
Motor mount issue?
I was able to take some pcitures of the mounts; since it is dificulry for me to know if a mount is in good service I was wondering if anyone here had an opinion:
First pic is the front starborad mount, notice the space between engine bed and tip of middle portion of the mount is a bit more than 3/8''
Second pic is the Aft starboard one, the same space is a bit less than 1/8''
Also, rubber in the aft one come above the metal part (see pcitures in next post), compared to front one.
Mounts in the port side are almost identica in spaces, look etc.
Thanks for any comments,
-Abraham
2 other pics, sorry, not great angles/quality
fron mount (rubber below teh top of the metal)
Aft mount (rubber squashed, comming out over top of metal)
Abraham
Can I just add to the advice from our fellow members and suggest that the engine mounts may be the problem as you suspect.
A while back, I ran over a mooring line which fouled the prop and stalled the engine. When I cleared the prop, and started the engine it ran extremely roughly to the point where I thought it would jump of the mounts!
Anyway when I got back to my slip there was no visible damage or change in the mounts. I had the boat checked out by a mechanic friend who said, from his inspection, that it was unlikely to be the mounts but more likely to be damage to one or all of the prop, strut, shaft or cutlass bearing.
Anway to cut a long story short, I ordered 4 new OEM Universal mounts from one of the Marine Parts Suppliers (Note: Listed in catalog as Isolators) and after installation and aligning the drive train, the motor now runs as smooth as silk at all revs.
Thanks peter, I agreed. Annoyed that I would need to haul the boat to change the mounts but will see.
Abraham -
There is absolutely no need at all to haul the boat to redo the motor mounts. Replacing them was one of the first jobs I did on our boat when we bought her 4 years ago (per the surveyor's finding that they were shot); you just need to hoist up the engine a few inches to slip the new ones in. As I recall, the prop shaft and the exhaust riser needed to be disconnected (and the wood bulkhead removed), but nothing else. I raised the engine with a come-along and a bit of chain attached to a piece of 4x4 wood resting over the hatchway. Not a pleasant job, and some (interesting) contortions to get at some of the bolts, but not mechanically very complex. The worst part was repeated trips to the store to get more socket wrench extensions to get at some of the harder to reach bolts on the mounts (particularly the aft starboard one).
I replaced with the Vetus K75, as suggested by Soko. You should keep track of the existing height measurements, I used these as a starting point with the replacements before realigning the engine and found they were not far off.
Good luck!
Thanks Matthew. I went ahead and changed the motor mounts with original ones (way overprices but for some stupifd reason I thought it would simplify the process). In any case the job was very easy, done in the water, and vibration and noise has been reduce by an enormous ammount. I am very happy with it. I will shoot a short video of the old mounts this evening and post it here, they look pretty bad to me.
-Abraham
Happy to hear that you finally had your problem fixed. It is very helpful to have fellow owners sharing their experience. I am a new owner too and found this forum very helpful.
Just want to share that my idle is only 600 and it rattles but once I push the throttle up to 800 it became very smooth. However, my max rpm only goes up to 2400. A bit of white / grey smoke start to come out from exhaust at 2200. So I always try to keep it under 2200 yet still gives me cruising speed about 6 knots into current (1-2 knots). Is it normal to have some smoke? If I kept the engine running at higher then 2200 rpm for over 2 hours, I always have to scrub off the black stain on the transom after returning to slip which is annoying.
After , reading thru the post regarding the engine mount, I want to attach this picture to ask if I need to tighten the nut on the top mount. It is not tightened all the way to the mount!
Also, Is it easy to adjust my idle from 600 to 800 so there is no rattling on start?
Please advise.
Jason Hui
Richmond BC
Hull# 2041 Year 2001
Fin Keel , Tall rig
M-35B (KUBOTA V1305-E block) RH 15" x 9" 3 blade bronze prop
Jason, A few things. Please make sure that that nut is completely tight. Not sure why it is that way, the lose nut is probably making your engine jump all over the place, that is not normal (you need a 15/16 wrench). You could break stuff if leave it like that.
Regarding the RPM, as stated by the manual, your engine should be able to achieve 3000 RPM under load. There is something wrong in your case if you can only get it to 2400 RPM. These are my suggestions:
1. Check with a handheld tachometer that the RPM are correct (match the engine tachometer)
2. Is the bottom clean? Are the shaft and prop clean? Maybe dive to make sure
3. Have you make any other changes to your engine lately? If you have, I would look at the last thing you did before you got this problem.
Finally, your idle RPM should be between 800 and 1000 RPM as per the manual. See number one above to make sure your 600 is real. Adjusting the idle is extremely easy, a screwdriver and a small wrench will do. Happy to explain further is you need to go that route.
Others probably will have many more suggestions.
Hope this helps.
-Abraham
PS. For those of you following this discussion (original vibration problem), changing to new motor mounts made a huge difference, problem is almost gone.
For what it's worth I added a "Blue Hump" Hose to my boat and I think there is less vibration. I added it because it's a good idea.
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
Hi Chuck
do you have a pic on where the blue hump fits!
regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
http://www.abclubhk.com/
Hi Abrahan
Can you explain how to adjust the idle on the engine?
I will take your advise and tighten all the nuts on the engine mount.
Jason
Jason Hui
Richmond BC
Fin Keel , Tall rig
Andres
I haven't taken a pic of this hose. I can, if needed.
This hose is a "Blue silcone hose" Available from Catalina direct. This hose is connected to the exhaust riser to aqua lift. The OEM hose is very hard and stiff. The reason I swapped out the hose was to reduce vibration to the aqua lift. If you do a search for the blue hump hose you'll find many write ups.
Chuck Lennox
97 MKii Ventura Ca
Andres,
Here's a pic of the blue hump hose (center of pic) recently installed in my 1987 MkI. It might be slightly different in the MkII, but not much. Hope this helps.
Tom, Chuck
Thanks for the explanation and for the pic, I am still a newbie and many times a photo is worth a million words :)
is the vibration reduced considerably?
have you also noticed the improvement?
BTW, how often do you replace the exhaust riser?
what sort of insulation do you have (sound/fire)?
regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
Andres,
The blue silicone hump hose does not reduce the engine vibration. It's purpose is to not transmit the engine's vibration to the aqualift muffler (and thus the hull), weakening and eventually breaking the large fiberglass hose nipples on the muffler. I suppose that if less vibration is transmitted thru the hull, it might seem as if the engine is vibrating less, but that's just your senses deceiving you.
In the 18 years I owned Julandra, I only replaced the exhaust riser once. The insulation on the underside of the aft cabin shelf was more of a reflective heat shield. Other posts have mentioned that automotive exhaust wrap can be used to wrap the exhaust riser. I have NO idea if you can find that in HK!!! :-) In the states you can go to just about any "Speed Shop" and get it. Hope this helps.
Thanks Tom
I'll see what I can find
regards
Andres
Andres & Arantzazu
S/V "Carpe Diem"
Hull: 1773
1999 C36 mkII
Hong Kong
Jason - sent you a PM, regarding adjusting idle...
Jason, sorry for the late response. I see that you got a pm about this but just in case, look at the m35 owners manual available in this site, page 24. You will see a screw to adjust the max speed, it is a horizontal screw with a nut. Same looking screw to the left of it, but vertical, is the one to adjust the idle. Use a phillips screwdriver and a wrench, release the nut and adjust the screw by turning right for higher idle, do this slowly and , repeat at needed.
hope this helps
