Engine coolant pump seized, kubota part numbers?
ewente's picture
ewente
Just as we were about to leave the dock yesterday, our engine coolant water pump just completely seized.   (not the fresh water impeller, but rather the antifreeze pump)  It created an unforgettable squealing noise from the fan belt and smoke as it rounded the stopped pulley, and I had the admiral pull the engine stop immediately.   There were new rusty water/antifreeze drips on the absorbent pad in the bilge, but the failure came without warning and I was glad it happened before we left the slip.   I haven't pulled it yet, but I'm certain the shaft bearing is toast.  Anyway, do any of you have a suggestion of a good kubota dealer online and what part number I need for an M-25  (this is a MK-1 boat, so it's the old M-25 not M-25xp)  I don't want to buy the Universal part and pay the boat tax for a tractor part.
Ellsworth
Ellsworth Wente
S/V Wind Dancer, C-36MkI hull #256
Messick's
http://www.messicks.com/
You'll need your engine block model number, it likely is in the Owner's Encyclopedia on the main website.
Members-> Encyclopedias on the menu at the top of the page.
Edit:
Found It
http://www.catalina36.org/members/encyclopedias/kubota-equivalents
Regarding the fresh water coolant pump; please see my post from last year:  http://www.catalina36.org/comment/53499#comment-53499
There are two versions of this pump, depending on diameter of pump's metal impeller.
My Kubota part number was 16241-73034 ...
ewente's picture
ewente
I found a new 15534-73030 water pump on ebay for $55 that is for the D850 - (M-25) and looks right.  Heading down to the boat this afternoon to slap it on.
Ell
Ellsworth Wente
gmckear
Well as Luck would have it I had a similar day today water pump seized at least I was still in the slip if it’s got to break that is the place you want it to happen. My engine is a M25 also I looked up the replacement pump you purchased on eBay  just was wondweing if you installed it yet and did it fit ok?
Thanks for any help you can provide
Pat McKearan
S/V BIT BUCKET
1986 C36 #531
N'awlins La
ewente's picture
ewente
Hi Pat,  The pump was a perfect fit, and no problems at all.   We've put about 2 hours on it already.   I didn't paint mine because I didn't have any paint handy at the time, but you might want to grab a can of the Universal engine paint or rustoleum and spray it before installing it.
Ell
Ellsworth Wente
