Loos Gauge
Talisman
Loos Gauge
Ok. Now I've got one. What do I do with it.
Can anyone describe how I should tune my stays and shrouds on my tall, wing, '98 36' with my loos gauge?
Enrique
Talisman hull #1673
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
Tom Neary
There should be a chart on the gauge showing what the % of breaking point is for the diameter wire being tuned. I know on my boat the shrouds and back stay are 5/16 in dia. and the mid stays are 1/4 in dia. Follow the instructions on how to install the gauge on the wire and using the chart for reference the 5/16 shrouds should be tuned to 12% on the gauge and the 1/4 mid stays 9 to 10% now keep in mind you will be going back and forth between stays and shrouds eying up the mast for straightness. Once this is achieved go out and sail to see if its to your satisfaction you might have to fine tune and adjust! It is a process and be prepared to spend some time with it! But in the end your rig will be properly tuned. Hope this helps.
Tom Neary X Aviator
Flying Vertical
Cat 36 MK I #616 1986
SSYC Milwaukee, Wis.
