I believe I have the standard ST50, which lights up, but does not appear to be working correctly.
A quick look up to the top of the mast determines that the wind pointy thing is stuck in one position, and the spinny thing isn't spinning.
I hiked the mast yesterday and these units were indeed very frozen. They are both mounted on a rod which is easily unscrewed from the base. I removed the mounting rod and units and hosed them down with McLube. They started to move a little bit, but I came to the conclusion that this part of the system will have to be replaced.
When I got back down I looked back up, and the spinny thing was now spinning and pointy thing appeared to be pointing a little.
I looked at gauge and it was now registering direction, but not wind speed.
I am going to have to replace the top unit and wondering if this is a generic unit or an actual Raymarine unit?
Blair White
2004 C36 MKII # 2169 "Dash"
Pacific Beach, CA
These are indeed Raymarine-only transducer units; which Raymarine has apparently made obsolete. ST60 units are very similar, but apparently not compatible. You may find used replacements on E-bay; or might be able to get a marine electronics rebuild on them, since the wind cups are not 'broken', just seized.
Good luck Blair - and let us all know the result.
Seized, yep that's the right word.
Thanks for the advice. It looks like I am on a part search now.
Blair White
Pacific Beach, CA
So, I'm opening this thread back up because my ST50 wind speed indicator is not spinning, and having removed it and looking and feeling the armature I have determined that the bearings need replacing. Has anyone ever done this, and or bought the bearings from the guy in GB that has them on EBay? I have found some directions through Google for removing the bearings, but not totally comprehensible for my feeble brain. Thus, I need more info before I pay good $$ for small parts with no directions that still won't get the job done.
Second part.-- Will the ST60 transducer work on the ST50 connection? I have found conflicting reports here and nothing has been definitive. Any responses will be greatly appreciated.
Thanks, Bill
Bill Taylor
Heel'n Good #1612
Washington, NC
Bill, I am having the same issue with my wind indicator. Did you ever find a fix.
Jules Cardin
Catharsis
1995 Catalina MKll
Marion, MA
Jules, I had the yard man go up my mast and take the transducer off and lower it down to me. I carefully pulled the cup mount apart, made sure there was no dirt inside, and then sprayed with electronic cleaner, and put back together. I had no Idea that that would fix anything. However, the cups began to spin somewhat on my trip back to the slip very intermitently which gave hope. The next week I came back to the boat and everything worked. The wind speed is still working after a whole summer so I must have done something right. There are instructions on line ( Google search ST50 wind) that tell you how to pull those things apart to replace the electronics or to troubleshoot. Read them, and they will give you a good understanding of the inner workings. Good luck.
Bill Taylor
Heel'n Good #1612
Washington, NC
Email me off line at chiclasser1@yahoo.com. I have a guy in England that will rebuild your transducer. I had same problem last yr, sent to him for a rebuild over winter and works like new.
Chic Lasser
Past Commodore c36ia
Great Lakes sales Rep Mack Sails and Rigging
