Bilge hose thru-hull
gorgonshead
Hi --
I'm going to be adding a dedicated thru-hull at the aft starboard side for a second bilge pump. Is it necessary to drill this out at a larger size, fill in with resin, and then drill out at the size of the through hull?
Peter L
Peter Lundquist
s/v Rafael
1998 Catalina 36
Hull #1669
Salem, MA
Catalina hulls are solid fibreglass so no need to do that. I'm assuming you are suggesting this process to block off core material from water intrusion? Decks are a different story.
gorgonshead
Yes, that IS what I was thinking. Thanks.
Peter Lundquist
s/v Rafael
1998 Catalina 36
Hull #1669
Salem, MA
