This may sound dumb, but what tool is used to open the water ports to fill your boat? I am a new owner of a boat that was stripped, and have nothing, not tools. I am starting from scratch... Any additional info helpful.. Thanks
Some of mine you push on a "rocker" in the deck fill cap and it rocks up a twist handle. Others will open with a winch handle.
Gary Matthesen
"Holiday"
1987 #50646
Oyster Bay Long Island NY
Depends on the type of cap. If it has two holes in the top, you can get a device from any marine store that fits into the holes and acts as a handle. When really tight, I use my Leatherman pliers, put the tips in the holes and twist. Some caps use the winch handle... if the cap has a hole on top that looks like the top of the winch, use your winch handle.
The 1999 model came with the metal filler cap which uses a "key" which has two holes and a wide slot. West Marine has a universal style metal key which fits it perfectly and has a bit more leverage and grip than the small original ones which came with the boat.
[url]http://www.westmarine.com/deck-fills/davis-instruments--universal-deck-p...
Here is what the original looks like only metal [url]http://www.westmarine.com/deck-fills/perko--plastic-deck-key-fits-1-1-4-... Correction - the original was all metal, but did not include the handle part, just a smaller part with a small grip area above the two points.
Gene Foraker
Sandusky Yacht Club
Sandusky, OH
1999 C36 #1786
Gypsy Wagon
Any marine store will sell the special tool, but I generally prefer to use a pair of needle-nosed pliers anyways.
Thank you gentlemen.. the deck key! Just ordered 2.. B
Why 2, you'll never, ever, not even once, drop one overboard :p
