Hi folks, I could use some help finding a replacement speed/temp transducer. I'm brand new to our Catalina 36mkii 1997. I'm pretty sure it was originally hooked to a ST 50 head. I have looked though past posts and it looks like maybe it was made by Airmar? Is Catalina Direct a good source?
Chuck
Island girl
Ventura Ca
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
ST50 & st50+ were made by Autohelm for your years vintage. This company was bought out by Raymarine and the ST50's are now obsolete (might find a used one on Ebay)
I believe you can replace with an ST60+ transducer unit, but you'd better check first before buying...
Check out this link: [url]http://commutercruiser.com/are-your-old-autohelm-tridata-electronics-ext... as there is apparently a company that might be able to hook you up with the correct txducer.
I replaced mine several years ago with an airmar transducer. I only had to splice the wires to the original transducer wires. Works great.
2000 MKII
#1896 Sweet Caroline
