Microwave Found ?
9 posts / 0 new
SailorJackson's picture
SailorJackson
Microwave Found ?
The small space allowed to fit a microwave has been a discussion in this forum in the past. My 2006 microwave started flaking out last year and I had spent a lot of time searching, unable to find anything under 10.1" in height.
Now I see that there is a GE model (JE740DRWW) which is available at Home Depot and a few other places which might fit. It's listed as 9-7/8 height which seems about right. I'd run out and try it but my boat is 100 miles from here. Anybody know if that model would work?
Greg Jackson
SV Jacqui Marie
2004 C36, MKII
tall rig, wing keel,
windward1
This might be a winner. I had given up looking. The smallest I had been able to find is 10 1/8" which is a little too high for my space. I am currently in Florida and it will be several weeks before I get to my boat to measure the space again. I will post my findings.
Richard
1994 C36 Tall Rig M1.5
Waukegan Harbor
Lake Michigan
Greg,
I just went down to my 1999 model and my microwave measures 8.5 inches high. There is a header board across the top of the opening which appears that it could be cut down at least 1.5 inches to allow a higher unit to install.
Hope that helps.
windward1
Today at my boat I measured the shelf height opening above the stove. 9 3/4" would be a very tight fit; if it would fit. I would be looking for a max of 9 1/2". As mentioned in an earlier thread; I found a very small microwave on Craig's list that fit in the space. It must be at least 20 years old and has a dial (before touch pads), but it warms things and still works.
Richard
Waukegan Harbor
Lake Michigan
William Miller
Since I have a 1990 I do not know if our space is the same but I cut down the bottom lip and was able to fit a 10 + in micro wave into the spot
windward1
Bill,
I think that is the only alternative.
Richard
Richard
Waukegan Harbor
Lake Michigan
R.K.OUELLETTE
My microwave in my 2005 MK II is a GE JE620BF/WF
I AM LOOKING AT THE SPEC SHEET I PULLED FROM G.E.'S WEBSITE
THE EXTERIOR DIMENSIONS ARE AS FOLLOWS
WIDTH IN INCHES 18" 9/64THS
HEIGHT " " 9" 23/32
DEPTH " " 12" 27/32
I UNDERSTAND THAT THE MICROWAVE HAS BEEN DISCONTINUED BUT SOMETHING OF THAT DIMENSIONS MUST BE AVAILABLE.
SailorJackson
The one I found is current mode: GE model (JE740DRWW) and their web site says it's 9-7/8" tall. I ordered one, but found that the web site is in error. The actual dimension is 10.19". Still no solution.
Greg Jackson
SV Jacqui Marie
2004 C36, MKII
Kevin
I found a source that has over 50 microwave ovens available now.
email me at Kevin.silver@verizon.net for contact info
