[U]Oct 15 2013[/U]: I bought the boat and launched it. On the 1/4 mile trip from launch to marina, the engine overheated (pinched raw water hose) and the muffler blew. It ripped down the side at a previous epoxy repair. (see pic)
[U]After 5 months re-wiring the boat[/U], I finally fired up the engine again yesterday with the [U]new[/U] Aqualift muffler.
After 5 minutes, I raised the RPMs above idle and heard a LOUD BANG down below. [U]The muffler had blown right off it's base![/U] (separating at the seam)
1) I've read accounts of engines overheating and shutting down, but not blowing mufflers open!
2) I blew into exhaust hose, and the only resistance was the trapped water in the exhaust hose where it loops up and back down & out (easy for me to blow through)
3) Are the [U]FOUR mounting screws[/U] required for the designed strength to keep the muffler intact? The holes were not pre-drilled, and since the port and forward facing sides are inaccessible, I just put one screw aft, and one on Sbrd side. Muffler blew right off these! I had thought that the short in & out hoses were enough to hold the muffler, and only put the 2 screws in to help secure vibrations. [U][B]But are theses 4 screws actually for structural integrity, holding the base to the box??
[/B][/U] (if not, I have no other theory)
I can glass and repair it, but why does it keep blowing?
Here's the old muffler. Do they blow when the engine overheats? (Engine was barely warm yesterday when the NEW muffler blew apart). Defect? or "Human error".. missing screws?
[IMG]https://lh3.googleusercontent.com/-ECOpJ7-ZDPo/Un2E205-h5I/AAAAAAAAHPw/h...
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
North Puget Sound, WA
Paul,
I have never had that blew but reading your post makes me wonder. If you have one that you can measure down into the tubes and get the length of each. From the top of the tube to the bottom down in the box. I am thinking that one tube is shorter then the other and maybe it was hooked up backwards. I did not see the drain petcock in the picture. That should be facing the rear of the boat, As ours is. If one tube is shorter and hooked up backwards it could create more back pressure I am guessing. Let me know what you find on the tube lengths.
I just read on the Catalina Direct web site that the outlet tube extends to the bottom of the box and inlet does not, Could the first one been hooked up wrong and you followed suit hooking up the new one the same way? Just a thought.
Here's what's inside: [url]http://c34.org/bbs/index.php/topic,6728.0[/url]
Thanks guys,
Randy, that pic of my old muffler is showing forward/sbrd sides. The drain plug is around the corner.
Interesting note on the drain plug: Catalina says you are supposed to use it to drain the extra water in the muffler if you spend to much time cranking the engine without it starting.
So far the only stories of muffler failure seem to be about the broken/corroded inlet/outlets.
I have the blueprint copy with specs. So when I peel the rest of the bottom away I can verify that it was built correctly. You certainly cannot install it backwards!
As I said, the mounting holes were not pre-drilled. So, at first, I actually drilled from the TOP of the flange, as it was easier to attach that way to the plywood mount. I fired up the engine and water sprayed out those holes!!! (from the FLANGE!) So I brought muffler back home, epoxied and glassed up the holes and re drilled 2 on the sides, securing TWO points, not FOUR like the original. The exploding pressure blew those 2 points right off!!
This new muffler is signed on the back that it was tested at 4psi for five minutes. (4 psi only!?!?) But that would be without the mounting screws further holding the 2 pieces together.
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Here's the new blown aqualift. Yes the aqua lifted it right off it's base.
[IMG]https://lh3.googleusercontent.com/-QdmaTDAwQBs/UyXyDyqKfwI/AAAAAAAAKgI/b...
Do NOT drill into the TOP of the flange!
[IMG]https://lh5.googleusercontent.com/-U1k0X1GwMo0/UyXyFICrijI/AAAAAAAAKgY/R...
ONE mounting hole on just 2 sides did not prevent it from exploding.
[IMG]https://lh4.googleusercontent.com/-P3aWdh4-LHA/UyXyEDiucaI/AAAAAAAAKgc/N...
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Follow up question:
Does anyone know how the exhaust hose is routed? [U]Does it have a dip in it[/U] between the muffler and transom where water collects? Would this create excessive back pressure? (I heard the bubbles when I blew into it)
I saw a pic that Stu posted re-hosing his C34 exhaust, and it looked like the mid section was completely straight, such that any water in the hose would either drain OUT or BACK IN to the muffler, but not be trapped.
ps I've been reading lots of posts about small "drip" leaks in aqualifts. Mine does not drip but shoots out water with great force... finally resulting in the bottom blowing out.
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Paul
I had a new muffler made by a company in Bellimgham ,price was just over 100$ and they did a better job then Catalina and it fit perfect
My guess is that you have too much back pressure. Some part of the exhaust after the water lift muffler is blocked. The water lift muffler works on the same principal as a water pipe.... Is there a brass check valve in the hose? They are known to fail. Try taking a garden hose and sealing it into the the exhaust end closest to the muffler. Turn on the water, there should be no back pressure, and water should flow out of the stern exhaust, the water may wash out any blockage. Just an idea. :)
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Hi Paul,
Is it possible the PO installed a gate valve or ball valve on the through hull fitting for the exhaust? If so, even though it may be open it may be partially plugged. The exhaust hose on our 1989 model exits the top of the aqua lift and travels up to just under the combing between the outboard wall of the port side lazarette and the hull then aft to the transom and down to the through hull fitting, exiting just under the transom. Hope this helps.
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
Thanks for the tip Bill. I think I can reseal this new aqualift ok. I just want to know why they keep blowing.
Really Ross? A check valve in the exhaust hose? I'll have to check that. I'm leaning toward the excessive back pressure though. Even though I can blow through it myself, there is definitely water in the hose that I'm blowing through.
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Paul,
I'm curious, is the boat in the water or on the hard? Also note that the pic's Stu led you to show that the screws that tie the water-lift down, go through the flange (top to bottom). This is how mine is secured on my boat and was the same with the Catalina 30 I had. In the pictures you included of the new aqualift it appears the four holes (original) are epoxied in? The test date on the bottom makes me wonder if this is a salvaged water-lift? Perhaps this was a problem to start with?
The reason I'm asking if the boat is in the water is, on my 30' when I would throttle up, the stern would push down into the water when making way, thus making the exhaust outlet also under water. The temperature would rise. My thought was that this caused back-pressure.200-300 RPM would make a difference. No science here just an observation.
Paul,
It was my C30 that had the Check valve in it, but my understanding is that some think it will help water back flow to the engine. This was a common issue with the early C30. Have you tried taking a plumbers snake and working it up through the exhaust. You could have a nest or something in there especially if the boat sat on the hard for a while.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Your first failure seems to have been caused by excessive heat in the aqua-lift caused by restricted injected water (pinched hose) into the riser. Might have been the reason for the epoxy repair in the first place. Exhaust sounds are both muffled by the aqua-lift AND the exhaust gasses are cooled by injected water so that components downstream of the riser don't melt.
Your second failure might be heat related as well. When you throttled up, a seam weakened by heat would give up at that point due increased air volume and thus pressure. [B]You should systematically verify that sufficient water is being injected into the riser, that the riser injection point is not restricted, and that the entire wet-exhaust hose is not inhibiting flow.[/B]
Finally, a down-dip in the wet exhaust hose to the point where it collects water is not ideal as this would be a place for all kinds of nasty things to happen. Ideally, you should have an up-slope reaching well above the waterline and then only down-slope immediately at the stern.
Thank you guys for the great suggestions & input.
Gary, the boat is in the water (since Oct). It sat on the hard for 6 yrs, slowly being repaired of a snapped rudder/bent shaft after washing ashore in the Katrina storm surge.
The date on this new Aqualift is 6/7/13. It was brand new.
I'll copy at the bottom (from my email to Catalina Direct) the reason for the glassed holes.
Ross, today (after swim practice) I'll go to the boat and scope out the exhaust hose. If it DOES have a check valve, that would explain the bubbling I get when I blow into it.
Nick: Thanks so much for that excellent input. I think you may be closest to the problem. While it was idling for 5-10 minutes before I raised the rpms, it was burbling away out the transom, but to my novice ears (my trailer sailer had an outboard) [U]there was not as much water coming out as I expected.[/U] Water was burbling out, I just expected more. Certainly water was shooting out under pressure inside when it blew!
The raw water hose was replaced (no longer pinched). But maybe the pump is dying? So I need to research now how to test for adequate raw water flow, in addition to eliminating any possible exhaust hose blockage undetected by my blowing into it (mouth to hose).
[B]Sorry for this long post.[/B]
Here's what I explained to Catalina Direct my reason for glassing the mounting holes.
QUOTE:
My question: Does muffler design require all four corner mounting screws in order to withstand exhaust pressure, or is the fiberglass seal supposed to be enough?
I did not have all 4 screws fastened into the plywood base, due to inaccessibility of port and forward sides of muffler. I assumed the short/rigid in/out hoses would secure the muffler, and 2 screws would suffice to minimize vibration.
(note you will see in the pic that the 4 corner holes are now glassed shut. That was my doing, because last week when I first fired it up, it leaked from several of these holes! When I first installed it, I drilled an additional hole on the OUTER EDGE of the mounting flange on the starboard side for extra security, since I couldn't reach the opposite side, as mentioned above. It ESPECIALLY leaked with force through this hole. So I removed the muffler, glassed ALL the holes shut, and then drilled 2 holes low down on the downward (vertical) edge of the flange, into the plywood... (That's where the original factory holes were on the original muffler). These 2 new holes blew right out with the force of the exploding bottom when I reinstalled it, started the motor, and, after 5-10 minutes raised the rpms.)
UNQUOTE
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Paul, a few months ago I was fortunate enough to purchase a slightly used muffler from another sailor over on co.com for the price of shipping. Nice guy. Anyway, it was sitting in my garage (awaiting install since the inlet port on my 26 year old muffler is pretty well shot), so I took these pictures.
1. The holes go through the flange. I haven't looked at the one in my boat, but I'm pretty sure they do, too, since that's how Ron Hill wrote it up in his muffler replacement article in Mainsheet magazine, probably also on our C34 Tech wiki, but I'm not sure about that. If you look UNDERNEATH the muffler, as long as the hole don't impinge on the BODY of the muffler, they're just for hold-downs using the flange.
2. My earlier reads on your issue, due primarily to having two blow up on you is EITHER (a) you have a restriction in the exhaust line, whether it's a check valve or a dip in the line; [B][U]and/or[/U][/B] (b) you may have installed the inlet and outlet backwards. The higher one is the INLET, the lower one closer to the drain cock is the outlet.
This muffler has the "tested" written on the back, too. It is an OEM factory muffler.
Our exhaust outlet goes underwater when we rev up the engine at higher throttle. I have had no issues with this in 15 years. Nor did the PO who owned the boat for its first 12 years.
Well Paul. If you can blow into the hose and push water out the back of the boat with your breath. I am stumped then.
I completely agree that having the exhaust outlet under the hull go under water by a few inches is an insignificant factor. The additional hydrostatic pressure created by submerging the outlet 3 inches under the water surface is about 0.12 PSI.
Thanks guys.
Well I can't check the raw water flow volume until I put the muffler back in.
But here's what I found today with the exhaust hose.
1) it appears to be quite new.
2) it was put in with too much slack: about 18" both fore & aft. When it goes through the wall after leaving the muffler, it dips DOWN a foot before turning up toward lazarette. Then, as it comes out from the lazarette area, it goes UP again before it goes down and out the stern. In both locations, water was trapped. I don't know how this effects back pressure.
3) I tried to run a garden hose through it (just plastic hose, no end fitting) From both ends, it STOPPED right where it turns to go down from "lazarette area". This may be a pinch, a kink, a fitting? (elbow? check valve?) but I can't get to it, to see or feel. I'm going to have to pull the exhaust hose out one direction or another to check :eek::( What a pain!!
Although I CAN blow through it, now that the water is out of it, I can tell there is SOME resistance. A hose that size shouldn't have ANY resistance.
This boat is determined for me to know intimately every system and every square inch. And I haven't even gone topside yet!!
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
I'd suggest making the investment of pulling the exhaust hose off the boat, stretch it out (if possible), and look through it. Alternatively, pull the exhaust hose and run a water hose with the water running through it (to stiffen the hose), making sure the entire diameter of the exhaust hose is clear. When you go to re-install it, route it so that there's a continuous up-slope from the aqua-lift to well above water line (to prevent following seas from making it back to your engine) and from that point a continuous down-slope to exhaust pipe. No sharp bends.
Testing water injection is more art than science as I don't have flow rates. Use your best judgement. Again, make sure the injection point in your riser is clear (insert a screw driver into the injection point) as this is a common place for corrosion to inhibit flow. Assemble your complete system, start your engine and check your exhaust pipe at the stern. You should hear a "slosh....gurgle.....slosh" . At idle, not much water will be flowing with [B]each slosh[/B], but some and it should be slightly warm. Throttle up. More slosh than gurgle, more water, still slightly warm.
Finally, if you do suspect low water flow, then with a cold engine disconnect the injection point, direct the hose into a 1 gallon container such as an antifreeze jug. Start the engine, idle only, exactly 15 seconds, shut down. From winterizing my engine, it seems like that gallon container would be maybe half full. I've only winterized once, so other owners might have a better feel of the flow rate of the raw water pump at idle for 15 seconds. [COLOR="Red"][B]Don't operate your engine for too long like this as you're not cooling the exhaust with the injector hose disconnected.[/B][/COLOR]
Paul, First I will apologise, but it just have to comment on your last statement.
But there is nothing better than getting intimate with the one you love. :D
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Paul,
Many years ago I went to a diesel seminar at a local W/U distributor (Hansen Marine), and one of the things the instructor mentioned was exactly what you are looking for. He said that a cooling system which is working properly will push about 10 gallons of water thru it per minute, at 3000 RPM. I can't remember if it was for the M25 or the M25XP, but they should both be very similar:
[URL]http://www.c36ia.com/node/294[/URL]
Once you get things assembled, now at least you have a benchmark. Hope this helps.
[QUOTE=Wavelength;21685]Paul, First I will apologise, but it just have to comment on your last statement.
But there is nothing better than getting intimate with the one you love. :D[/QUOTE]
Thanks Ross. Good on you for not stretching the metaphor about my "not having gone topside yet";)
Nick & Tom thanks again. I see that I have the Sherwood raw water pump. Maybe rather than focusing on water volume, I should just take it off and inspect the impeller.
But I will certainly inspect the injection point in the riser as you suggest Nick. Good idea.
Meanwhile I'm waiting for the bright idea bulb to come on with SOMETHING to attach to the exhaust hose so I can pull it back through. Normally you would attach the NEW hose that you're replacing. But I'm not replacing it. I'm afraid that attaching anything smaller will not force the hose to line up with the holes in the walls, esp behind the lazarette... and just leave it stuck.
Any creative ideas will be rewarded with my great admiration!
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
[QUOTE=plebel;21713]
Any creative ideas will be rewarded with my great admiration![/QUOTE]
You really need two people. Our experience was that the "tag line" method probably wouldn't have worked.
Pictures here:
[url]http://c34.org/bbs/index.php/topic,6760.msg45301.html#msg45301[/url]
Not so much different than yours.
I agree, based on my experience on my 30 2 or 3 people working pushing and pulling a few inches at a time..... no real fun but it works. The rubber on the sticks to everything making it impossible to just slide it through.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
[SIZE="5"]FOUND IT![/SIZE]
I suspected the exhaust hose was crimped right on the other side of the hole going up to the port side locker area. That's where the garden hose stopped. I pulled it through and there it is! No wonder my mufflers were blowing up!
As someone said: "Ah those P.O.s!"
Now, as for the muffler. I'm leaning toward using 5200 to reseal the inside (rather than resin), and then running a length fiberglass around the seam/edge. [U] Does that sound ok?[/U]
This time I'll also make sure it's screwed into the plywood base to help it hold together, then just use adhesive to glue the plywood the other wood bits already glued to the hull.
[IMG]https://lh6.googleusercontent.com/-W3GDEEDHx4g/Uyz3Mk6Hh4I/AAAAAAAAKg0/6...
[IMG]https://lh4.googleusercontent.com/-_wwzDH_d_vg/Uyz58aZKx2I/AAAAAAAAKhg/v...
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
Nothing like 5200 "the Devils" for a permanent seal.
Are you able to get the kink out of the hose?
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Yeah Ross, Like I said, there's a good 18" too much hose at each end, which caused it to buckle AND form dips where water collected. I'll just pull the crimped part through the hole as shown, probably put a hose clamp around it to keep it round, then cut off all the extra hose gathered at the muffler end.
ps Stu: Yep, once I got the fridge compressor out of the way, I was down inside that locker, with my arm in the hole, just like the picture of your son :-)
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
So THAT'S what the inside looks like! Another thing you could use is thickened epoxy. When you drill new holes for the screws, make sure you only drill thru the edge of the flange, and not thru the cavity. As you now know, the screws are only to hold the muffler in place on top of the base, and not to hold it together. Good find for the cause of the blown mufflers!
Interesting to read your story Paul, your face seems to pop up on many adventures! Just a point of interest, in my last boat, with a Yanmar J3HJ engine, I put a thru hull wood plug in the exhaust outlet for a winter. The following spring I forgot to remove it. It was a bit hard to start, but when it did it blew the plug clear across to the next dock. The hoses , engine and waterlift continued to operate normally. You must have developed alot of pressure in that thing to blow it apart!
Talk with you guys next successful story solved.
Gary
Gary Matthesen
"Holiday"
1987 #50646
Oyster Bay Long Island NY
Just a thought and agreement with what Tom Soko suggested. You can use heat to soften 5200 and where this is the escape for the exhaust and the ability of pressure building, I would go for the thickened epoxy. use a good measure of it on the flange where you would/will drill/re-drill your holes.
[QUOTE=Gary Bain;21797]Just a thought and agreement with what Tom Soko suggested. You can use heat to soften 5200 and where this is the escape for the exhaust and the ability of pressure building, I would go for the thickened epoxy. use a good measure of it on the flange where you would/will drill/re-drill your holes.[/QUOTE]
Dang I didn't think of that. Too late. I just sealed it with 5200 today. I already had a tube of it. But I'm still planning to seal the seam edges again with fiberglass, and then [U]fasten it[/U] with screws to the plywood base. Hopefully it'll hold. If not, I'll just become the muffler expert.:rolleyes:
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
LOL....Good Luck and hope you can be done with this project.
[QUOTE=plebel;21801]Dang I didn't think of that. Too late. I just sealed it with 5200 today. I already had a tube of it. But I'm still planning to seal the seam edges again with fiberglass, and then [U]fasten it[/U] with screws to the plywood base. Hopefully it'll hold. If not, I'll just become the muffler expert.:rolleyes:[/QUOTE]
Don't over think it. Since you've cleared the block on the exhaust hose, which many of us suspected was your culprit, just take it slow and go from there. I think you'll be just fine.
Thanks Stu. I am taking it slow... giving it the full 8 days to cure. Meanwhile, I've moved on to the engine panel, replacing the corroded 30 yr old wiring, that sat in the port locker with no cover/protection from the elements! FUN FUN....
Today's my favorite day: 7-9 swim practice followed by a WHOLE day tinkering on the boat while listening to Saturday NPR radio programs :)
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
