Sacrificial anodes
Talisman
Sacrificial anodes
Some of you may have noticed article in Cruising magazine about this subject. It made a believable story for using aluminum anodes instead of my usual zincs. Also I believe the ones for our engines are zinc.
What are people using?
Enrique
Talisman, '98 36' MK2 tall rig shoal draft.
On the hard South Glastonbery, CT
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
I have always used zinc anodes. Haven't read the article yet.
Talisman
I have also. The article speaks of the zincs getting a white coating on them and being ineffective if in brackish or fresh water. I kept my boat in the CT river for several years and remember the white coating on my zincs at fall haul out.
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
fstbttms's picture
fstbttms
Clean bottoms are FastBottoms!
baysailor2000's picture
baysailor2000
I have a question regarding zinc. When I purchased my c36 - I found several sizes of zincs amount other tools that came with the boat. The one that is 1/4" goes on the heat exchanger. I also found two other sizes that are more like 3/8" and 1/2" in diameter that screws into an end-cap. Where do they go? Does the water heater need zinc? Is there one on the engine? If so where are they located at?
Coyote Point, San Mateo, CA.
Haro, I figure you have an M25 series engine. There is ONLY ONE zinc, in the HX shell. That's it.
The water heater has an OPTIONAL anode that replaces the drain valve on the front of the heater. Most folks we know of don't have one. They are available from Seaward (Whale bought them a few years ago, so you'll have to find a distributor - I bought a new heater a few months ago and got a great price from Sure Marine in Seattle).
Capt. Sam's picture
Capt. Sam
I too read the Cruising World article with interest. I keep my boat on the St. Marks River. Way up the river where the water is completely fresh. But All my sailing and cruising is out in the Gulf of Mexico in salt. I've seen this white coating on my heat exchanger zinc. Now I'm confused as to what I should use since my system is exposed to complete fresh, complete salt and of course a mix in between. Should I just ignore this issue and keep the zinc zincs?
Help me oh wise ones.
:o
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
baysailor2000
Stu thanks for the info. I have M35B Westerbeke Engine.
