Catalina rudder bearing fix
10 posts / 0 new
Rob Kyles's picture
Rob Kyles
Has anyone actually tried the Catalina fix of pouring epoxy down the rudder tube to stop the side ways slop? Was it easy to do? Did it work? Has it lasted time?
My boat builder is reluctant to try it, as he feels it wouldn't work
S.V. Wind Star
Online
Have you tried another Catalina suggestion- obtaining some overhead projection film (Mylar sheets) from Staples and slipping them between the post and tube to rebuild thickness- no epoxy
Rob Kyles's picture
Rob Kyles
Haven't tried that either, thanks for the heads up!
Has anyone had success with this fix?
S.V. Wind Star
Wavelength's picture
Wavelength
I did the epoxy thing with my 1976 Catalina 30. Used epoxy with graphite mixed in. Not a fun job but it did work. The work needs to be done on the hard so you can plug the bottom edge with modelling clay.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Rob Kyles's picture
Rob Kyles
Thanks, Ross... how long ago was that?
S.V. Wind Star
Gsmith's picture
Gsmith
I repaired a loose rudder post using UHMW sheet material on a Islander 28. It's available from McMaster Carr in various thicknesses. Cut strips about 1-1/2" wide and wrapped around post. The repair lasted a several years before the sheet material wore rubbing against the harder glass rudder tube. Next step was the epoxy repair but sold the boat before I got that far
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
M35A Oberdorfer conversion
Wavelength
Rob,
I purchased my C30 about 7 years ago. Purchased as salvage after a hurricane in the NE. Sold her 3 years ago when I purchased my C36. Buy old goods and fix them up. I guess I will have to get a 40 foot plus for the next up grade....:eek:
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Rob Kyles's picture
Rob Kyles
Thanks Gary, I think I might pursue the packing line of attack... Did you find once around the shaft enough? Also did you have to glue it in place or did it stay up in the tube. (ie any sign it worked it's way out of the tube)
S.V. Wind Star
Gsmith's picture
Gsmith
Rob
The rudder on the Islander was easily dropped so I lowered it about 3 inches. Not knowing the exact slop in the rudder post I bought several thicknesses of UHMW sheet hoping that I'd be able to use just one layer wrapped around the shaft. As it turned out I used two different thicknesses with one wrap each. I cut the seam on a diagonal and staggered these opposite of each other. I ended up with a fairly tight fit and was concerned at first that I'd end up with too much resistance, but within a short time it wore in and remained consistent for several years. The shims were not glued into the post, just held in place and lifted the rudder back into place with a slight interference fit. The inside of the rudder post was somewhat rough and not necessarily round either so it wasn't a perfect fix but the shim material filled the gap and was an easy and quick solution at the time.
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
Rob Kyles's picture
Rob Kyles
Thanks, Gary, that's exactly the info I was hoping for :-)
S.V. Wind Star
