Wheel pilot connector
9 posts / 0 new
alexanne
Trying to get my old AH4000 pilot to work. Discovered the bulkhead connector that the control unit plugs into is broken beyond repair. It is a 4 pin connector and they are not made any more, does anyone maybe have one?
Alex H.
SV Alexanne, 1985 #432 SR
SF Marina Bay YH
tomfoolery
Alex I had a 3000 that the plug failed on me I can't remember if it was 2or 4 pin i cut both ends out and replaced them. You might be better off finding a new 4 pin male/female set of connectors and replacing both the plug and socket ? There are some good water resistant connectors out there. See downwind marine.com dc connectors for example looks like there is a Wella 4 pin plug and base
Tom Irwin
North Saanich, BC, Canada
1983 Catalina 30 - #3134
Until June 10, 2013
Have you considered removing the connectors and splicing the wires?
alexanne
Toms suggestion about a new connector may be the answer. I need to be able to unplug the control unit when not in use.
Alex H.
SF Marina Bay YH
Alex, understood. Have you considered Radio Shack? I'm sure they have four, five, six to a gazillion pin connectors of all various shapes and sizes. Good luck.
jviss
This is a perennial problem: there don't seem to be many, or any, good, marine bulkhead connectors sets.
I have a retired AH4000, and had some trouble with the connector on that.
There's an ancient connector design still available:
[URL="http://www.westmarine.com/webapp/wcs/stores/servlet/Product_11151_10001_..."]http://www.westmarine.com/webapp/wcs/stores/servlet/Product_11151_10001_...
[IMG]http://content.westmarine.com/images/catalog/full/181867.jpg[/IMG]
May be your best option.
alexanne
Thanks everyone for the input. Found a 4 pin connector at Svendsons Marine. Sea Dog #426234-1 did a temporary connect and every thing works!!
Have to learn how to use it now.
Alex H.
SF Marina Bay YH
tomfoolery
Great to hear Alexanne, this site is an extra good reason to sail a Catalina 36! Once you figure your AP out you will never want to be without one.
Tom Irwin
Until June 10, 2013
dejavu's picture
dejavu
Thanks for the find, Alex. My connector is getting a bit dodgey and I have to wiggle it a bit to get it to stay connected. A bit unnerving when singlehanding not to know when Otto will suddenly decide to head to the beach.:eek:
