THARs your problem...
RPowers's picture
RPowers
[B]Symptom: [/B] Water appearing on the galley floor, from behind the panel under the garbage holder. Where was the water coming from?
[B]Finding:[/B] Looking in the back cabin engine access panels, I could see the exhaust path. A bulging hose on the wet exhaust pipe and STEAM spraying out under pressure was leaking water all over the place. Holy mackerel Batman!
[B]Fix:[/B] New hose, new clamps, thank gosh!
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
Rick,
Glad you found the leak, but some would say you've gone backwards. The blue hose you replaced is known as a single hump silicone hose. It was not OEM, but was added by the PO to help solve another problem. With the thick, black, stiff hose you put on, the engine vibrations are more easily transmitted to the aqua-lift muffler, and might result in cracks and leaks in the muffler and its fittings. You might want to order a new silicone hump hose to replace the split one you took off. Just a thought.
RPowers's picture
RPowers
Ah, I didn't realize that the bulge was intentional and silicone was for flexibility.
Hmm, makes sense. I see Catalina Direct has them for $36
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
And Rick's membership in our Association just paid another dividend. Thanks, Tom!
RPowers's picture
RPowers
OK, here is the new hose section.
Nice piece of hose!
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
Phil L's picture
Phil L
[QUOTE=TomSoko;18892]Rick,
Glad you found the leak, but some would say you've gone backwards. The blue hose you replaced is known as a single hump silicone hose. It was not OEM, but was added by the PO to help solve another problem. With the thick, black, stiff hose you put on, [B]the engine vibrations are more easily transmitted to the aqua-lift muffler, and might result in cracks and leaks in the muffler and its fittings.[/B] You might want to order a new silicone hump hose to replace the split one you took off. Just a thought.[/QUOTE]
Precisely what happened to me.
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
RPowers's picture
RPowers
How did you know that your water lift muffler was compromised?
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
