Found this in the boxes of tools and parts left on the boat boat by the PO. If you look at the bottom, it has a bit of a notch from whatever it used on. Anybody know what this thing is used for???
Thanks--Joel S.
Joel Schwartz
s/v Get-A-Grip
1993 Catalina 36 Hull #1259
Newport Beach, California
PS The bar appears to be made out of aluminum, is about 1/4 inch thick, and about a foot long.
Joel Schwartz
s/v Get-A-Grip
Just taking a stab at what I can see. If that is a piece of line on the end I am guessing it is for your windlass up front if you have one. You say it is about 1/4 thick. Is it about a inch to a inch and quarter wide?
Yep, you nailed it. What does that thing do?
Joel Schwartz
s/v Get-A-Grip
Its to allow you to manually use the windless should your power to it fail. I've never used mine but as I recall from reading the windless lit, there are some things you have to do to use it. I think the bar manually releases the windless brake by going into a slot on the windless and acting as a lever.
See page 32 of the vw800 windlass manual. Part 55. Page 20 for use.
It is on the c36ia site
Tom Irwin
North Saanich, BC, Canada
1983 Catalina 30 - #3134
Until June 10, 2013
Thanks guys...glad I didn't let me 2 year old keep playing with it the other day...he loves to throw things overboard!
Joel Schwartz
s/v Get-A-Grip
