Anyone know here a bow light lens can be had? Seems that mine somehow went to a watery grave (with a little help from the frost bite sailers across from me)
"Jem'nI
Cat 36 MKII #2004
Annapolis, Md
"Jem'nI
Cat 36 MKII #2004
Annapolis, Md
Theme by Zymphonies
Replaced ours 2 years ago after a storm event. Catalina Direct 27.95.
Jim Gibbons
S/V Just Add H2O #1503
Chicago-Lake Michigan
1995 C-36 MKII TR/SK M35AC
Aqua Signal was the manufacturer on our boat (1996). Series 25.
[url]http://www.pyacht.com/aquasignal-series-25-lights.htm[/url]
Jack
Solstice
Hull #1598
Lake Texoma
www.texomasailing.org
Go ahead and buy a new one but buy LED, they are amazingly bright. One tip is check the new housing and the LED bulb unit you plan to use together. As of a couple of years ago the newer unit bow housings and the LED units did not match. The LED may swing from side-to-side in the housing. I replaced mine as part of a LED upgrade before going to Mexico and had to make some modifications before it fit well and the LED bulb unit was secure. I have been happy with the upgrade.
John Meyer
Currently in La Paz
John Meyer
Hilbre
C36 MKll, Hull 2135
