Prop shaft length MKII
11 posts / 0 new
jemni
has anyone replace a prop shaft on a MKII? I'm trying to confirm what Ken told me that the shaft was 52"
"Jem'nI
Cat 36 MKII #2004
Annapolis, Md
2sailaway's picture
2sailaway
Check out the info found here, I just replaced my MKI and the size was exactly as described here but measure your's to be sure. You should also add a signature to your profile with your Hull info.
[URL="http://www.catalina36.org/node/1107"]http://www.catalina36.org/node/1107[/URL]
Larry Robcke
Finally someone asked a question that I can competently answer!
52 inches tip to tail. It's right here beside my desk and I had a tape measure handy. I keep it here to remind me of the 'joys' of charter boat ownership.
[QUOTE=LCBrandt;16844] I keep it here to remind me of the 'joys' of charter boat ownership.[/QUOTE]
:eek:
I remember being in Desolation Sound and seeing a friend's boat come in. My wife says, "theres the Smiths"
Nope; just 9 'twenty-somethings' that rented their boat for the week.
Part-ied all night long...
jmcelwee
I'll verify this as well. I just replaced mine last month, and it was 52".
Josh McElwee
jemni
Catalina Direct is asking for the "set" length...can anyone confirm that? It seems to be the lenght minus the threaded end. I'm a liveaboard and I dont want the boat on the hard for two weeks while I measure, order, ect
Thx
"Jem'nI
Cat 36 MKII #2004
Annapolis, Md
Bill, I can measure it for you, but please make sure what a "set length" is. Let me know, as I have the shaft here beside my desk.
jemni
Thx Larry, take a look at this link from Catalina direct
[url]http://catalinadirect.com/index.cfm?fuseaction=product.display&product_I...
"Jem'nI
Cat 36 MKII #2004
Annapolis, Md
I get 50 5/8 inches by their definition.
Breezly
Going slightly off topic (apologies offered from the outset :)) I take, from reading these posts, that the shaft cannot be reversed. I was hoping I could switch ends and get some further life out of my shaft.
Can someone tell me if I can or cannot? Many thanks.
Robert and Louise
Breezly
Catalina 36 MkII
2000 Hull number 1864
http://www.sailblogs.com/member/breezly/
Robert,
Correct, you cannot reverse a prop shaft to get more use out of it. One end is "blunt", and the other is tapered and threaded.
