Replacing M25 exhaust elbow
alexanne
Hi, I am a new member, in the final stages of the purchase of a 1985 C36 #432. Among other things the exhaust needs looking after... I previously owned a C30 so am somewhat familiar with the system. I do not like the pipe elbow contraption that Catalina uses I think it can be improved. Westerbeke makes a cast riser that is much better, but then I came across this one from Moyer Marine... It is the ultimate simplicity, anyone tried one yet?
"Inline cooling water exhaust entry fitting
The tapered pipe threads on top of this fitting are 1-1/4", and the hose barb on the bottom is sized to accept 1-5/8" ID exhaust hose. The inlet fitting on the side is sized to accommodate 1/2" ID hose."
Alex Lorenz
C36 #0432 SR Alexanne
Alex H.
SV Alexanne, 1985 #432 SR
SF Marina Bay YH
benethridge's picture
benethridge
I'm interested coz I repaired mine last year. (See my post elsewhere on that.)
However, I don't really see how it works yet from your description and the picture. Seems like you would still need an "elbow" somewhere.
Ben Ethridge
1984 MK1 Hull# 263
Our inlet water line to the nipple is 5/8", yours may be, too.
alexanne
I am thinking that you could use this to inject the water after the manifold and use a side inlet (Vernalift) muffler. Then you can run exhaust hose to the muffler and may not have to insulate anything. Vernalift says muffler needs to be 2' away and the top 12" below exhaust. I think 1/2" would let enough water in, may have to make an adapter.
Alex
Alex H.
SF Marina Bay YH
MitchMan406's picture
MitchMan406
 "The tapered pipe threads on top of this fitting are 1-1/4", and the hose barb on the bottom is sized to accept 1-5/8" ID exhaust hose. The inlet fitting on the side is sized to accommodate 1/2" ID hose."
Good find!
Awesome info here.
This will save me a pretty penny!
Thanks, Alexanne!
Mitch
1986 Catalina 36 MKI
S/V "Blessing"
Kema, TX
Hull: #584
M25 w/ Oberdorfer Conversion
