brookhouse NMEA mulitplexor
Ciscocat's picture
Ciscocat
I am considering purchasing a multiplexer along with a iMux wifi device that will allow my wind,depth and knotmeter to interface to my ipad, i believe it will also allow connection to and from the X5 autopilot that i have. any one have any experience good or bad with bookhouse or any of their products?
I know the arguments about Ipads not being as robust as dedicated chartplotters but i have been using mine for sometime with a lifepruf cover and it has worked well to this point. I have iNavX as a navigation tool and that seems to work well and it has the ability to interface with the sailing instruments.
Mike Hogan
s/v Ciscocat #226
Mark I XP25, std rig
bcam's picture
bcam
[QUOTE=ciscocat;15823]I am considering purchasing a multiplexer along with a iMux wifi device that will allow my wind,depth and knotmeter to interface to my ipad, i believe it will also allow connection to and from the X5 autopilot that i have. any one have any experience good or bad with bookhouse or any of their products?
I know the arguments about Ipads not being as robust as dedicated chartplotters but i have been using mine for sometime with a lifepruf cover and it has worked well to this point. I have iNavX as a navigation tool and that seems to work well and it has the ability to interface with the sailing instruments.[/QUOTE]
If you get it working, consider adding IRegatta to your Ipad. It adds a lot of functions that make sailing more efficient and fun.
The big boat I sail on added a DMK box to create a wifi setup and IRegatta is a great addition to the Ipad.
Bruce Campbell
Evergreen Dreams #1409
Ciscocat's picture
Ciscocat
Thanks for the suggestion if I get it working ill write something up with pics and see if I can get it posted
Mike Hogan
s/v Ciscocat #226
[quote=ciscocat;15831]Thanks for the suggestion if I get it working ill write something up with pics and see if I can get it posted[/quote]
Absolutely Mike, if you can do that and send it to either myself or Steve Frost that would make a great article for the tech library on the website.
