Cabinet Latches
10 posts / 0 new
catalinapilot
Cabinet Latches
One of the latches on our '00 MKII has failed. Thoughts on sourcing a replacement? I suppose Catalina parts could help but thought I'd try the forum first.
Bruce
Southern Comfort #1881
Tall rig, Wing Keel
caprice 1050
I bought two at WM.
I found that a well stocked hardware store has many of the same parts.
catalinapilot
These are the twist turn type and there must be 20 or more on the boat. looks like they may have been made in Sweden?
Bruce
Tall rig, Wing Keel
I think I know which type of latch you're referring to; my '97 MkII has 6 of them, one for the drawer under the galley sink, 3 for the drawers and 2 for the tilt out bins under the forward berth. I have not seen a replacement part for those. I seem to recall calling Catalina (many years ago) and they didn't really know the part or supplier, as they didn't use them anymore.
I replaced all of the knuckle buster latches with the push/pull latches Catalina used in later models. I got mine from Fawcetts in Annapolis; their online store now takes you to pyacht, so don't know what they have.
I just got the latest catalog from Lee Valley/Veritas; they have every kind of cabinet hardware known to man, but don't have that latch. They do have push/pull latches similar to what I got at fawcetts; part numbers are 00S22.10 (brass) 00S22.20 Nickel. Not sure if that's any help or you can find something that will serve your needs.
Bruce, Catalina throughout the years of production used several different types of latches. It might be helpful if you posted a photo of the latch. I had to replace a latch a few years back on my 2002 boat and, if I recall correctly, I found it at Catalina Direct.
Do you mean this one: (interior latch)
[IMG]http://i117.photobucket.com/albums/o51/Z00dles/Boating/int_latch.jpg[/IMG]
I had one broken in my galley area.
Cat Direct calls it the 'new improved version', but the centre piece is silver and my originals are black, so I swapped it out with the engine access one in the aft cabin so that they all matched in my main cabin....
Ciscocat's picture
Ciscocat
Catalinadirect.com has then at [url]http://www.catalinadirect.com/index.cfm?fuseaction=product.display&produ... I believe they may also be available at the limber mill that sell teak in CA I don't recall the name but the are less expensive than Catalina direct. I had something build there and they include then I'll try and find the name and post it I believe the charged me about 15 buck as opposed to the25 that CD wants
Mike Hogan
s/v Ciscocat #226
Mark I XP25, std rig
Mike and others:
H&L Marine woodwork, Inc.
2965 East Harcourt Street
Rancho Dominquez, CA 90221
323-636-1718 310-638-8746
Fax 323-636-1720
email: [email]H.1@sbcglobal.net[/email]
If you get on their mailing list they'll send you b&w fliers every once in a awhile.
VermontSailor's picture
VermontSailor
The latches on our 1999 MKII are made by Southco, MP-series.
The MP-series and the later M1-series (Pop-out) latches are here.
[URL="http://www.southco.com/product/default.aspx?hid=7483"]http://www.southco.com/product/default.aspx?hid=7483[/URL]
Parts list
[URL="http://www.southco.com/product/partlist.aspx?cid=7472"]http://www.southco.com/product/partlist.aspx?cid=7472[/URL]
MP-01-103-515 Black handle, chrome cup
MP-01-103-511 Chrome handle, chrome cup
Google the part numbers to find a source.
MP-01-103-515 - $23.38
[URL="http://www.searay-parts.com/Mobella-Novibra-push-to-close-latch-by-South..."]http://www.searay-parts.com/Mobella-Novibra-push-to-close-latch-by-South...
Unfortunately the newer M1-series (Pop-out) cannot directly replace the MP-series.
The M1’s have a mounting hole of 1-1/2 inches in diameter and the MP’s have a mounting hole of 1-1/4 inches in diameter.
Nile Schneider
Mañana C36 #1798
Lake Champlain, VT
