Mast Boot Tape
Roland
Mast Boot Tape
I just bought a roll of mast boot tape (still trying to cut down on water freezing in the bilge). The tape doesn't seem to be very sticky. Is there some way to insure that the tape will stick to the mast?
Roland
Blithe Spirit
C36MkII #1762
Wavelength's picture
Wavelength
Clean the mast with a detergent and a kitchen scrub pad (fine Scothbrite). Rinse with clean water and make sure it is dry.
I recently discovered the tape they use in stores to mark lines on the floors works really well. It is a vinyl tape designed to be removed but sticks well. I purchased it through a industrial supplier.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
Roland,
You will find that this tape does not act like regular tape. First, as you expressed it does not appear sticky. Second, you will need to start raping it around the mast and pulling tight as you cover the previous layer, then low and behold, it bonds to the previous layer. I have used it for 2 years with great success and my largest problem is keeping the boatyard from cutting it at the top of the mast boot I use when they unstep the mast in October.
Roland
Thanks, Gary. Your comment was just what I wanted to know.
Roland
Blithe Spirit
#1762
benethridge's picture
benethridge
Can't I just use good ole duct tape?
Ben Ethridge
1984 MK1 Hull# 263
[QUOTE]Can't I just use good ole duct tape?[/QUOTE]
Works for Red Green! Maybe only Canadians will get that?
benethridge
I also have this silicone "rescue tape", which looks an awful lot like the (more expensive) "mast boot" tape. Can I use that instead and save some $$$?
Ben Ethridge
1984 MK1 Hull# 263
Some of us Yanks have laughed at Red Green numerous times.
