To haul or not to haul
12 posts / 0 new
rtrinkle's picture
rtrinkle
I was wondering what opinions are out there regarding hauling their boat for the winter.
We keep our boat in the Lower Chesapeake Bay, and just had the bottom stripped, barrier coat, expoxy, and painted during the no wind month of August this year.
If we keep it in the water this winter, we will plan on making trips to the boat a couple weekends a month.
If we haul out, then probably just day trips for winter projects.
All opinions welcomed.
Robert Trinkle
Universal M35A
Kinsale Harbor Marina
Kinsale, VA
We haul because we pretty much have to in the great frozen north. But if I lived were you do I likely would not haul every year. It's a lot of work spring and fall though most of it is in winterizing and covering the boat. On the upside, I get a close look at the bottom and can easily inspect the mast and rigging on the ground every year.
Wavelength's picture
Wavelength
If you can not sail her, haul your boat and cover it, the boat will last longer. You are protecting the fiberglass from UV and you are letting the hull dry out. Yes, fiberglass does absorb water over time. FUll inspectionof the hull and rigging can be done.
As said, up north there is not much of a choice.... Sailing is not a great option once the temperature goes below 3 to 5 C. Worse still ice forms on the river....Time to build an ice boat??? Global warming is making that questionable.... Every year we pull everthing possible off of the boat, especially soft goods, they will get moldy. When spring comes we only bring back what we need... You will be surprised at what clutter can build up in various storage areas.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
rtrinkle's picture
rtrinkle
I was actually thinking of getting a cover for Troubador. Great suggestions from all.
If we winterize, we probably will not sail her, but if still in the water, we would go down for the weekend and work on her. We have a portable electric heater that works great and warms the entire inside of the boat.
The reason we were considering leaving it in the water is because we just had the expense to haul it out in the summer for the bottom maintenance. So if we leave in the water this year, it would definitely be a haul out next year.
What does anyone think? Still looking for more info.
Robert Trinkle
Universal M35A
Kinsale, VA
If I was in your situation (and location) I would leave it in the water, your reasoning is sound given what you just had done. I expect your concern is going to be snow load since I gather you do occasionally get some significant snow down there.
People do leave their boats in all year round up here with a variety of de-icing solutions, mostly fans but some bubble. We get ice and lots of it. Our little marina is almost full this year, both on the hard and in the water, due to another marina nearby going TU for the 2nd time in about 5 years.
A few liveaboards are on the boats in the water, I can't imagine what that would be like in winter up here at -30C! They're all metered for hydro individually and one liveaboard told me he was spending about $250 a month on hydro for a 36' sailboat. Another one hauled last summer for the first time in 6 years, I was amazed at how clean the bottom was, just slime, but that's fresh water.
rtrinkle's picture
rtrinkle
Great thing with our boat, a bubbler conveyed with it. But it hasn't froze on the lower Chesapeake in like,, 80 years, so I'm not to concerned about that. Unless the 12/21/12 myth is actual.
We do get some snow, but not much by the bay. It usually stays more inland. But it still can be a concern. If its a rough winter, regional areas don't seem to matter and snow blankets everything
How do people normally deal with the weight of snow? Our last boat, we trailered every winter, so it really didn't matter. One friend of mine said he put multiple portable heaters around the inside of his boat to keep it warm, but that seems like an electrical hazard to me if left unattended for periods of time.
Robert Trinkle
Universal M35A
Kinsale, VA
Most just shovel it off, but some of the liveaboards build elaborate frameworks over the boat and cover that with 6 mil vapour barrier stretched tightly, the snow slides off it if you do it right. Plus it adds a lot of warmth to the boat through breaking the wind. They say it's quite pleasant on a sunny winter day, just like a sunroom.
bboggs's picture
bboggs
We sailed out of Stingray Point for several years and started on an every other year haul out schedule which I think is adequate to let the hull dry.
Fortunately the schedule worked well our first cycle after we moved north so we were in the water for last years very mild winter. We intend to haul this year. Snow and freezing of the creek is far more likely up here, so if I were in your shoes I'd likely stay in the water this year as Deltaville usually doesn't get very much snow even when the State gets some accumulation.
Bill Boggs
s/v Palmetto Moon
1991 C36, Hull 1128
Herrington Harbor South
rtrinkle's picture
rtrinkle
Thanks Bill and Bud. You all have solidified my decision. I'm gonna leave in the water this winter, and haul next winter. We will make trips to the boat for winter projects, probably 1 or 2 weekends a month.
I didn't think Deltaville got much snow, and you have confirmed. Thanks for that as well.
What did you think about Stingray Point? We think it is one of the prettiest marinas in the area, and really like the relationship with Stingray Point Boat Works, but don't care much for the potable water at the slips.
Robert Trinkle
Universal M35A
Kinsale, VA
One point of clarification. While it's true that polyester resin allows water to permeate through it and get wicked up in the fibers of the composite, with the Mark II's Catalina used vinylester gel coat and it is far more resistant to water than polyester is. Also, you've barrier coated your bottom which is epoxy, and epoxy is totally resistant to water. With a good bottom job, and it sounds like yours was well done, water should not permeate through the gel coat.
rtrinkle's picture
rtrinkle
Great, thanks for the extra words of confidence. Will probably haul out next winter, unless Hurricane Sandy poses a threat to us.
Robert Trinkle
Universal M35A
Kinsale, VA
Robert, Sandy is ON THE WAY. Time to make serious preparations.
