Engine Model
neilroach
Engine Model
Can't say why I'm just getting around to this but I am trying to determine the model of my M35 motor.
There is no data plate. I can see where it used to be, but alas, it is no longer.
So, should I be able to tell by year and Hull number or are there some identifying features that will tell the tale?
Neil Roach
"Crewless"
1992 36, Mark I
Hull # 1174
Seattle
Check this page:
[URL]http://shop.torresen.com/marine_diesel_direct/Universal/index.php?p=incl...
It doesn't have a lot of detail but from the dates I'd say yours is probably an M35 (no letter suffix). I understand that both it and the M35A are based on the Kubota V1200 engine and share a lot of parts.
Most Kubota engines have the Kubota model and S/N stamped into the block just below the injector pump mounting flange.
