Where does the bilge pump exit hose go?
10 posts / 0 new
RPowers's picture
RPowers
I tried tracing it's path, but lost track of it when it goes under the dinette table floor.
Reason I ask, is I don't seem to be getting drainage of my bilge, although the pump is working.
Where does the bilge pump hose exit the boat?
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
Should be on the transom, right between the rails of the swim ladder, when it's down. Will shoot you right in the face if you're slowly lowering yourself into the water:)
RPowers's picture
RPowers
What is the easiest way to check for blockage (or rather, free flow) of the bilge exit hose?
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
ProfDruhot's picture
ProfDruhot
On my 2001 MKII mine exits on the starboard side of the transom. I added a backup bilge and placed a through hull on the port side. To check for a blockage I would run something back up through the through hull.
Nimue's picture
Nimue
Its not uncommon for certain bilge pumps to fail to prime, so it will whirr away but not move any water down the hose. This is most common if you have too large of a bilge pump in too small of a space in the keel sump, and/or and old worn pump where the impeller is toast.
[QUOTE=Nimue;14032]Its not uncommon for certain bilge pumps to fail to prime, so it will whirr away but not move any water down the hose. This is most common if you have too large of a bilge pump in too small of a space in the keel sump, and/or and old worn pump where the impeller is toast.[/QUOTE]
Agreed. And I'd add that it's easy for the water inlets on the bottom plate to get clogged with slime and whatever nastiness gets into the bilge. You might want to remove the pump from the base and check it out.
Rick,
Not sure if I understand the true issue you are having, are your bilges full and you can not get any water out? If this is the case the previous posts have good suggestions. You can see water being discharged out at the transom when the pump is on if it is moving water.
If the bilge has some water in it but not full this may be normal, it is on my boat and I always use a sponge to remove the last of the water. If this is the case it is just due to the fact that the pump in the bilge pushes the water from the pump to the outlet at the transom uphill about 15 feet. After the pump shuts off gravity will cause the water in the line between the pump and the transom to run back into the bilge. A 1/2 line 15 feet long will hold about a quart of water that will flow back to the bilge.
Some have suggested a check valve at the pump to keep the water from coming back into the bilge. The problem with that is that if the valve sticks the pump will not work and you have a larger problem than just a bit of water sitting in the bottom of your bilge. If you have a check valve in the outlet line of your pump this could be your issue. If it is just this return water from the line and you just can not live with it I guess you could install a second pump wired in paralel with the main pump that would come on any time the main pump comes on and empty the line between the bilge pump and this second pump, for me the sponge works.
This may not be your issue, I was uncertain from your post but, seeing that you are fairly new to your boat I just wanted to make sure you were aware of this little trait.
RPowers's picture
RPowers
OK, first thing was clear, the hose exit is located on the starboard aft side, just below the "... MKii" logo.
I hand pumped the bilge low on water (or filth) then used cloth towels to get it dry. Then some soapy water with a little bit of bleach. Great, all clean.
Then, unclipped the bilge pump from the base, and disconnected the hose.
I removed and inspected the flapper (anti-reverse) valve, all good there.
When I removed it from the long section of hose, a lot of water (filth) came out. Great! I was then able to (with a glove over it for protection) blow out the hose, and could hear exhausting noises out the back, and clear flow from the bilge end. Great, all clear there!
I put it all back together, poured a bucket of bilge-soapy water, and was able to bilge-pump it out the stern successfully.
Hooray! A clean bilge is a happy bilge.
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
Rick,
One thing you might want to do is to run a fresh water hose in the bilge, and let the bilge pump do its thing for a while, cycling on and off. I do that every season to clean things out. Let the hose run into both the forward-most and aft-most compartments. The water will flow thru the limber holes to the compartment with the bilge pump. When you see that the water exiting the transom is clear, the bilge should be much cleaner. Just a thought.
RPowers's picture
RPowers
Yep:
I put it all back together, poured a bucket of bilge-soapy water (into the forward and aft cmptmts), and was able to bilge-pump it out the stern successfully.
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
