Hi friends,
Can anyone help identify the original purpose of this thru-hull fitting? I first though it was for the holding tank macerator pump, but that has its own, much narrower gauge fitting further inboard.
This is a 1.5" fitting capped with a PVC plumbing cap (which worries the heck out of me). It's located forward of the water heater and under the center dinette bench seat.
Thanks for any wisdom!
- nick
Nick Tonkin
I suspect it was the original overboard discharge for the head. I have the exact same thing on my boat. It would allow you to bypass the holding tank with a "Y" valve. If you were offshore for a period of time it might be something of value. Like conserving battery power.
Thanks Gary. Now I get it.
Nick Tonkin
