After 12 seasons on our MKII, the exhaust host is showing cracks on the outer layer so it's time for replacement. For the Hose - What diameter and about how long? From who m did you order it?
Anything tricky or what did you learn? It "seems" pretty straight forward but boat projects have a way of making Murphy look like an optimist.
Bruce
Southern Comfort #1881
Tall rig, Wing Keel
Hi there
We replaced ours locally when we noticed the cracks. Not sure of the size but we took the chance to add a 50mm shut off valve near the transom so we can shut off the exhaust if using a drogue (to prevent water being forced into the system) in a storm.
I've also thought to shut off the valve when leaving the boat on a mooring for months at a time, to keep salty air out of the engine - anyone have ideas on whether this is worthwhile?
S.V. Wind Star
The size of the hose should be printed in large letters on the hose itself. IRRC it's 1 /58".
As far as shutoff valves go, it may be a good idea in following seas, but the water will only go into the muffler. That's what the anti-siphon valve on the water line from the HX to the exhaust riser nipple is for. That anti-siphon needs to be serviced every once in a while.
As far as salty air out of the engine is concerned, I think not. That salty water is sitting in the muffler anyway. What purpose would it serve?
