diesel smell
jjesney
diesel smell
smell of diesel below deck, air the boat out and it's gane? The boat sits about a week each time, smell is back.
1986 MK I, Ideas?
James J, C36 MK I, Hull 537
Based on the age of the boat I suspect you will find that the fuel tank has begun to corrode at the bottom. It more than likely has small pin holes and only a small amount leaks out. It does not take very much to have the oder permeate the air and boat. Other than that it might be a leak at any of the fittings, but strongly suspect the tank is the problem.
And to get rid of the smell: [url]www.pureayre.com[/url]
