What to service on the mast when it's out...
13 posts / 0 new
rdmiani's picture
rdmiani
Hello...I sadly report our 2006 C36 has been in the boatyard for nearly 3 weeks with a mast step failure. Fortunately, it's getting taken care of very professionally. However, with the mast out, basically hung over a couple of workhorses, I'm sure there are things I can do to it before it goes back in. Besides a good cleaning with soap and water, the boatyard rigging shop suggested lubricating it in all the right areas. They also suggested replacing bulbs with LED equivalents.
Any advice on these and other topics would be greatly appreciated. Having just purchased this boat in Feb 2011, I'm thinking this is the first time the mast has been out.
Thanks for helping out. Talk with you soon...Rob - Hull #2265
Rob Miani
San Francisco Bay
2006 C36 Mk II
S/V Si Caro
Hull #: 2265
Laura's picture
Laura
Sounds like good advice to me. If you do decide to change to LEDs, I would assure that the connections are good and clean and that when you are ready to put it all back together, the seals are water tight.
One thing to consider is whether just the bulbs can be changed to LED or whether you need to replace the entire fixture. When we bought our 1989 C36, our anchor light fixture was completely shot, so we fully replaced it. I have converted many other lights by just switching to an LED bulb.
I wold also look at your spreader boots and how they are holding up.
Obviously, the most important structural check would be the integrity of your shrouds and stays and chainplates.
All of this is certainly easier while the mast is down.
Good luck getting her ready!
Laura Olsen
Past Commodore
S/V Miramar
Edgemere, MD
Peter Taylor's picture
Peter Taylor
If you have a TV in the boat and don't have a masthead antenna - now is the time to thread a coax cable down the aft conduit and mount an antenna at the top.
If you have a furling mast I'd seal the front and rear cavities of the mast section extrusion to stop water entry into the bilge as suggested to me by Charleston Spars.
I would suggest that if you change the lamps to LED - or even if you don't - that you get a small 12V battery (lawn mower battery(s), say) and apply power at the mast step wiring to validate that everything works before restepping the mast. An easy check now can save a lot of heartache later.
As Laura suggests, a complete rigging inspection is in order...looking for cracks in swages, etc.
As mentioned by Peter, installing any additional wiring would be appropriate now, even if you're only 'provisioning' for an eventual need. Radar wiring, wind computer wiring, AIS VHF antenna, TV wiring.
Take lots of photos and save for future reference.
tim_farrell's picture
tim_farrell
I would also examine all of the existing wiring and replace it if it is at all questionable. Wire is cheap, and getting it passed through the mast should be a breeze while it is down.
Tim Farrell
S.V. Kailua
C36 - 1986
Hull# CTY0678A886
Pete... How & where exactly did you seal the mast? Any pictures?
Clean and wax the mast and spreaders.
Check the spreader connections.
Replace the wiring if it is OEM lamp cord.
Replace the sheaves.
dejavu's picture
dejavu
[QUOTE=LCBrandt;9899]I would suggest that if you change the lamps to LED - or even if you don't - that you get a small 12V battery (lawn mower battery(s), say) and apply power at the mast step wiring to validate that everything works before restepping the mast. An easy check now can save a lot of heartache later.[/QUOTE]
Great idea Larry, I'm filing that one away. My '91 mast has several areas of corrosion around fittings, so I'm looking at pulling the mast at some point and having it repainted along with installing radar and other things as needed. Testing everything before you install the mast is smart (and I can't guarantee I would have thought of it:o)
rdmiani's picture
rdmiani
Thanks everyone, all great advice - Totally appreciated!
I'm heading down to the boatyard on Friday to meeting with the rigging foreman to go over everything stated here. I've printed it out so I can easily address them...
Curious to hear your can seal the top of the mast, I just assumed it sealed already. I do have an in mast furling, so I assumed water was coming in there when it rained. I'll ask the rigging shop about it...
Awesome idea about the TV antenna, thanks...
Overall, great stuff, thanks much...
Rob Miani
San Francisco Bay
2006 C36 Mk II
S/V Si Caro
Hull #: 2265
ProfDruhot's picture
ProfDruhot
What a bunch of gret ideas huh Rob?? You didn't mention if you have in-mast furling or not. If you do, I would certainly grease the moving parts if it is like mine. Isn't this forum fabulous?
Glen...
Where/how do you grease the roller furling? I know they say to, but I haven't seen any fittings and I don't want to spray anything onto the bearings as that usually is the death of them in our environment.
Peter Taylor
Chuck
You asked for info on how to seal the furling mast.
I'll reply in a separate post so it can be found when folks are searching the database - also it may raise some comments on this annoying problem.
rdmiani's picture
rdmiani
Hi All...I spent most of Saturday cleaning and waxing the mast. My wife went to town on all the lines and sheets, washing them to nearly brand new. I was able to lube some of the noted spots, but will actually be relying on the rigging crew to hit all the spots. I managed to clean the chain plates and shrouds so they look new again...
The rigging crew talked me out of the TV antenna and LEDs because we are not cruisers, and basically only sail the SF Bay. My wife actually doesn't want to watch TV on the boat, so I wasn't pushing that idea, though it was a good one...
I'm counting all the work being done this week so we can get back to sailing and hanging out on the boat. Thanks again for all your help! Much appreciated...
Rob Miani
San Francisco Bay
2006 C36 Mk II
S/V Si Caro
Hull #: 2265
