I'm considering shipping my mast rather than carry it on deck thru the Trent-Severn this June. My boat is currently 600 miles away from me in Sackets Harbor NY. I think it would be less thna 53 ft ? Thx
Chris Hansen
Hull 1889 wk std
White Lake, MI
Chris Hansen
Hull 1889 wk std
White Lake, MI
Theme by Zymphonies
Chris,
The extrusion is 50'2" (tall rig 2' longer). Add to that the masthead and anchor light, and you are lookng at about 51-52'. VHF antenna can easily be taken off.
Hey Chris:
As Tom says, its 50'-2" so it should go into a 53' trailer no problem. Where are you planning to re-step the mast? We are at Wye Heritage Marina (previously Doral Marine Resort) in Midland, Ontario, just around the corner from Port Severn. We have a mast crane for stepping where as some of the other marinas in our area only have a boom truck that goes from marina to marina at great expense for stepping the mast. You can PM me with your plans and I will do what ever I can to help you out.
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
