Galvanic Isolator
ProfDruhot's picture
ProfDruhot
Galvanic Isolator
This may be a silly question but I was wondering if our boats usually have a Galvanic Isolator installed form the factory. Does anyone know?
Ceiba's picture
Ceiba
Our boat (#2299) has a galvanic isolator installed by the factory in the starboard aft lazerette just to the port of the inlet main breaker for the 110VAC Shore Power.
Brett Colville
Ceiba I - Toronto
2006 Catalina 36 Mk II # 2299
WK | Std Furling Main Rig | Universal M35BC
Home Port: Mimico Cruising Club
hilbre
I had this question also some time ago as I did have documentation from the PO. I finally located it in the aft starboard locker, close to the main circuit breaker. It was factory installed. You have to look carefully as it is not too obvious.
John Meyer
Hilbre 2135 - San Pedro CA
John Meyer
Hilbre
C36 MKll, Hull 2135
Starboard lazarette. Here is what it looks like.
