When did MK II start?
willkaul
I have a 1990 with a split transom. I've seen 36's the same year without a split transom. Is that when the MK II model started?
Will,
According to Gerry Douglas, the first MkII was hull #1368, in 1994. Since inception there have always been incremental changes to the C36 (and all other Catalinas, for that matter). In 1990 or 1991 the walk-thru transom was offered as an option, and it often referred to as the Mk1.5. Hope this helps.
tgrover's picture
tgrover
To compliment what Tom Soko said, hull #1368 was the first MKII and hull #1040 had the first walk through transom, at least according to the attached drawing of the diffrent rudder types.
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
