Replacing the Shore Power Inlet
I just posted a [draft] article on the Maintenance tab explaining my recent changeout of the stock Hubbell shore power inlet with a new Marinco version. As the Mk II Tech Editor now, I am supposed to be able to add articles and photos. Apparently I have the adding the text part understood OK, but adding photos still eludes me. Alex Lynch is coaching me, and tomorrow I will attempt to add photos to the article using the method he emailed to me.
If you have a corroded or burned shore power inlet socket, stay tuned. It wasn't a very difficult job to replace the old one.
Finally I figured out how to load and format articles on the site. If you have any burned pins on your shore power socket, this article might help you build the courage to tackle the job of replacing the Inlet socket.
Nice write up Larry, some of the connectors looked like they got a bit crispy in there.
wfahey's picture
wfahey
Good article Larry. Thanks
s/v Lucky
1984 MK I Hull #266
San Antonio, Texas
