Wooden grabrail replacement
SailorJo
I have a 1984 C36 and need to replace one of the grabrails on the deck. Does anybody know where I can get these?
I live in the Vancouver BC area.
Owner of a Mk 1 C36 Hull # 379 commissioned December 1984.
Fin keel, standard rigging.
Boat is based in Nanaimo, B.C., Canada, where you will find one of the finest cruising areas in the world.
You have to count the number of loops. Then see if West Marine or other local chandleries have them in that length. Be very careful also of the length, spacing and dimensions of the loops. Sometimes the long length and number of loops that were used on our boats weren't available in standard off the shelf replacements. If that doesn't work, either try to glue the pieces together (you didn't explain the extent of the damage that required the replacement). Or call Catalina Yachts and see if they have them - I recognize the shipping issues entailed for you in Canada.
SailorJo
Thank you for your response.
I have repaired the broken one and glued it together but it does not look as good as an unbroken one.
I will try the stores like West Marine but when I go on their websites they do not have any mention of grab rails.
tgrover's picture
tgrover
Check out the following Catalina Direct Web Site: [url]http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Produ...
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
