Wanted to put up a quick post on Spartite for a roller furling mast. Saw where folks had used the "small" kit successfully on a non-rf. I bought the large assuming that my last is larger. note this kit is essentially two small kits.
a small kit has the perfect amount of Spartite and I used every bit of it.. I built the dam to keep the Spartite on the deck collar only and at ~2" in depth. So i only used half the Spartite.
However, I did use nearly all the Vaseline and clay.
if you get the small kit you may have to get some extra clay. It would be a nightmare to have a leak when pouring. But I'd say that's a lot less than the $60 difference between the two.
2000 C36 MKII 1825
