This topic has been covered before but just to update a little. My furler has gradually been getting harder to operate: last time I was out I could barely get my head sail in because the furler was so tight- had to use the winch. It is a Schaefer 2100. At the dock I confirmed that it had to be the bearing and ordered the replacement/upgraded bearing drum from Schaefer. I was pleased to learn that this part was still available and that Schaefer's upgrades are done so that they are still compatible with older units. $180. Biggest improvement is built in flush holes.
I found a short but informative video on youtube that covered the replacement:
https://www.youtube.com/watch?v=G5oyS4RotUI
Longest part of the process was loosening the rigging so I could disconnect the forestay. Other than a little anxiety about dropping some key part overboard, it all went together easily and now works like a charm.
The drum that I took off was completely frozen- could not be turned by hand. However it looks like it could be disassembled cleaned up and made functional again.
Paul Meyers
1986 Catalina 36
Hull #615
Ventura, California
My 1995 C36 had the Schaefer 2000 furler which had become hard to operate, and like Paul I had to resort to winching.
The 2000 has been replaced by the current 2100 which has a slightly larger diameter drum plus the flushing holes. Because of the larger drum the existing cage wouldn't fit so Schaefer sells the "2000/2100 Furler Drum Conversion Kit" Part No. SK-7390. This kit includes the drum, new cage, plus a spacer ring to adapt the existing torque tube to the larger drum. Price is $413 US.
Ken Akers
1995 C-36 MkII #1378 SR/FK M35A
San Francisco Bay
