Hello All,
I am putting a new dodger on the boat, and my canvas guy convinced me to go with the hard, polycarbonate windows because he says they are crystal clear, and remain so a lot longer than soft window material. However, he asked me a question that has kind of been bothering me about whether the traveler zippers on the hard windows need to travel up as high as the zippers on my soft windows. I told him yes, the zipper needs to go to the same height because I need to pull the traveler sheet up and out of the clamcleat to adjust the traveler. Is there something about hard windows that I need to know about that would make my canvas guy feel compelled to ask such a question? Do they have a tendency to crack or tear or break or ??? if zippers go too high in the middle of a window where the traveler line goes?
Also, any feedback on hard/polycarbonate windows would be most appreciated while I still have time to change my mind. One thing that I am having a hard time imagining is that these windows fold back and bungee to the underside of the dodger when opened, rather than rolling up as my soft window does. Does anybody have any experience with this setup? Does it work ok?
Thanks a bunch--JAS
Joel Schwartz
s/v Get-A-Grip
1993 Catalina 36 Hull #1259
Newport Beach, California
We replaced our dodger three years ago and went with the polycarbonate Windows. They remain clear, we love them. Not sure about your zipper configuration, but we haven't had any problems with the traveler. Our lines go through the canvas below the window. We also have the 'fold back' option, but find we use it very little since the windows are so clear. (And our temp isn't quite as warm as your area).
Bill Feyerherm
"Imagine" 1990 C36 # 1102
Friday Harbor, WA
Joel,
Rather than keeping the zipper for adjusting the traveler, you might want to give a call to Guido or Mark at Garhauer. They have several ways to route your traveler lines down to the cabintop, under the dodger (instead of thru it), and then to a cam cleat. Better and easier. Hope this helps.
I called Guido and bought the kit...thanks for the tip!
Joel Schwartz
s/v Get-A-Grip
Joel Schwartz
s/v Get-A-Grip
I just finished doing what Tom talkes about. My friend did this on his 30 catalina and it works perfect. Just rerun your line so it leads forward and put a sheve about 18 in forward of the traveler and rout the line under the dodger. I moved the cam cleat on either side of the hatchway on the top. Much easier to adjust and you do not have to go all the way up to the dodger
Thanks for the replies everybody:
You guys wouldn't by any chance have a picture of what you are talking about regarding rerouting of the traveler lines would you? For some reason I am having a hard time imagining precisely what you are talking about.
Joel Schwartz
s/v Get-A-Grip
Joel -Take a look at this comment I posted last year and the photos therein:
https://www.catalina36.org/comment/55992#comment-55992
which was part of a longer thread:
https://www.catalina36.org/forum/technical-discussion/revamping-control-...
(credit where due: Much of this redesign was inspired by Tom Soko's earlier writeup)
- Matthew
There are several grades of polycarbonate sheet. I would recommend the grade with a UV inhibitor to protect against sunlight damage ,and a mar resistant hard coating (silicone) to give it some abrasion resistance to salt crystals and other things. Use fresh water to clean it with a small amount of Dove (or similar) dish detergent. Keep chemicals away unless they specifically say that they are safe to use on polycarbonate. For being a bullet resistant plastic, it's achilles heel is exposure to chemicals. The hard coat helps in that respect too. Polycarbonate (ie Lexan) is a great product. I used to be a design engineer for the company produced it- General Electric Plastics Div.
2005 C36 MKII #2257
Got the windows with UV inhibitor...thanks for the advice!
Joel Schwartz
s/v Get-A-Grip
