new thermostat operating range 10 degrees too high
Coast Rider's picture
Coast Rider
 My new thermostat is operating between 185 and 200 degrees. My m25 Universal engine manual says 175 to 190 is the correct temp range. Should I shop around for a new thermostat or am I OK ?
Joe Lucido
1986 Catalina 36
Hull # 0625
M-25 Universal diesel
Oceanside, CA
caprice 1050
Joe
I mentioned this before, but I don't know the heat conditions in California. In the gulf of Mexico off Florida the summer Gulf temperature is as hot as 20 degrees hotter than the winter water temperature causing our engine to run about ten degrees or so hotter.
clennox's picture
clennox
My two cents: Step one make sure your gage is correct. I always double check with a known good gage.
​I spent a ton of time and money once thinking I had a heat problem, when it was the gage 10 degrees high.
Chuck Lennox
97 MKii Ventura Ca
Island Girl Hull #1611
Coast Rider
Hi Chuck,
correct. I checked with a laser temp gun. Thermostat housing was 15 degrees cooler.
Joe Lucido
1986 Catalina 36
Hull # 0625
Oceanside, CA
