Max Prop repair
tgrover's picture
tgrover
Max Prop repair
Hi All,
Has anyone ever had a cracked hub on a Max-Prop? It looks like I didn't get enough grease pumped into the hub to displace accumulated water in the hub while winterizing the boat. As a result, I have two longitudinal hairline cracks, each about 2" long, in the hub from water freezing. Has anyone experienced this in the past and has PYI been able to repair it? Just asking to determine if the prop is indeed reparable before sending it to PYI. Thanks very much for your input.
Tom & Janis Grover
C36 #0949
SR/WK, M25XP
Midland, ON
Give them a call. I've called them for non prop reasons and they were very helpful.
