Is there a furler section drain? The Charleston document refers to a "Water proof plug at deck level" which implies there is no drain. Does this section eventually overflow to the outside?? I searched the forum but couldn't find any references. Curious to know how this works.
My furling mast has a drain hole on the aft side above the deck. It gets clogged and has to be cleaned occasionally.
2000 MKII
#1896 Sweet Caroline
Thanks for the information.
Found the drain hole - sealed and taped over as part of the mast boot. Lots of water came out. Fortunately it was fresh water.
