Lubricating shift cable
ThreeForAll
Any suggestions on what to use to lubricate the shift cable? We tried some BoeShield or BoeLube, a lube designed by Boeing. After a week or so the shifter became very sluggish and now as the weather has gotten colder it is very difficulty to shift. We may just replace the entire cable but it would be nice to know what others are using to lube their cables.
Steve M, Greg E, Kevin W
ThreeForAll
1991 C36 Mk I, Hull 1119
Bellevue, WA
Steve,
I had the same problem a number of years ago. I spoke with Edson, and they told me that you really can't lube the cable effectively. If it is binding for any reason, it should be replaced.
Southpaws2's picture
Southpaws2
I just went through this exercise. The cable cannot be removed from the housing hence I couldn't figure out a way to lubricate it. I installed a new one and it has made a huge difference in how smooth the gear shifter now works. Too bad the boat is out of the water for the winter and I won't really be able to enjoy it until next spring.
Rick Verbeek
1999 C36 #1763
Toronto
Rick Verbeek
Southpaws
1999 C36 #1763
Lakeshore Yacht Club
Toronto
Gary Teeter's picture
Gary Teeter
Steve,
I have had good luck lubricating the cables with motor oil. Just remove the compass to get access, and apply a few drops of oil on the cable above where it comes out of the sheath. It will slowly soak down into the cable, and in a day or so the cable will operate much easier, in my experience.
I dip the end of a screwdriver in oil and then touch the clinging drop to the cable so oil only gets where I want it, and generally work the cables a few times to help get the oil into the sheath.
Gary Teeter
1989 C36 "AnnieG"
Std Rig #966, M25xp
On aircraft we deal with Teleflex cables like the one used on our boats often.
The cables are not really made to lube but, we have had good success by disconnecting the cable, finding a short piece of hose that fits over the end firmly, slipping the other end of the hose over a pump type oil can and pump the lube into the cable until it come out the oposite end. We have had the best luck with a teflon lube like Triflow.
ThreeForAll
Thanks for everyone's input. We ended up replacing the cable. Took a while to figure out how to get the old one out, but once that was accomplished, installing the new one was a breeze. What a difference a new cable makes.
ThreeForAll
Bellevue, WA
