Lower shroud mast tangs - where to purchase?
jrspadafora
We are currently in the process of replacing standing rigging and cannot find lower shroud mast tangs that are the same length as the ones currently on the boat.
We did find and purchase tangs from Dwyer Aluminum that have the same pin hole sizes but the tangs themselves are about two inches short.
Don't see the tangs on Catalina Direct. Besides custom machining any ideas on where we might find similarly sized tangs?
John
Mozark, 1986 Catalina 36
John Spadafora
S/V Mozarck
1986 Catalina 36
Hull # 623
Honolulu, HI
Ciscocat's picture
Ciscocat
I may be mistaken but I believe when I replaced mine I got then from Catalina. Check with Kent and he should be able to give you a part number. I believe they actually farm the work out to Garahuer. Seemed to be reasonable price when I purchased them about 4 years ago.
Good luck
Mike Hogan
s/v Ciscocat #226
Mark I XP25, std rig
jrspadafora
Thanks for the note Mike. We'll double check with Kent.
John Spadafora
S/V Mozarck
1986 Catalina 36
Hull # 623
Honolulu, HI
