Hi,
I find that water can seep into the galley dy locker thru the hatch whenever the counter surface above is wet.
Wondering if others have encountered this problem and come up with any solutions .... other than not being sloppy and get the counter wet!
Jeremy
Jeremy Westerman
"Odette", 2005 Catalina 36 Mk II, #2213
Benicia, CA
Hi jeremy,
I solved the problem by cutting a piece of teak to fit across just to the right of the locker.
I shaped it and rounded the top so that it looked the part, varnished it and carefully glued it to the counter top.
It is only about 10 -12 mm, but it does a great job of keeping the washing up water out of the dry locker.
hope this helps.
cheers
Kerry
Kerry Boden
Hi Kerry,
I was thinking of the same so glad to hear that it has been tried before and works.
Jeremy
Jeremy Westerman
Benicia, CA
