My gauges stopped working, and I did what every normal person would do and rewired the ground. After all, that's the common thread, right?
Nope. So I'm heading back up this weekend (it's 4 hours away) and I am suspecting the common purple wire from the alternator. Does anybody know what the output on that is?
I was on the hard, so I wasn't able to run the engine long to play around, but now that it is in the water I will be playing with my multimeter.
Hummina
1987 Catalina 36 MKI
#741
Bayfield, WI. Usually.
Anybody? I'm four hours away from my boat, and I'm unable to find any information on it.
Has anyone had problems with the wiring? I wired it exactly according to the schematic and the start button no longer worked. Adding a hot jump wire to the start button starts it, but I don't think that is a permanent solution.
Hummina
#741
John,
What engine do you have and who made the alternator you are using ?? It is probably not the original alternator that came with your engine. Purple is normally the engine instrument connection from the alternator.B+. Are you saying all your instruments quit working at one time, tach too ?
M25XP. I'm thinking it's the original alternator. Yup, all the instruments quit, but If I jump the red wire to the lights on the gauges, th lights go on, which has me thinking the ground is fine.
Hummina
#741
John;
As yes, the purple wire. To get this done correctly, it may not be as easy as one thinks. First you need to know what alternator you have mounted on your engine. Take a look at this page (link below) and try and determine what brand alternator you have mounted on your engine. There are many different brands & types and many different wiring configurations. That will be the place to start. If you suspect that your alternator is going bad have it tested at a local shop. It might be a good idea anyway. May be that you need a replacement and the alternaltor technician will be able to guide you through the selection and correct wiring configuration for your engine. Make a note of what wire is what before removal. If you have the original Motorola alternator as supplied with some XP 25 and M-30 engines, it is no longer made but is easily replaced with newer models. It may also be possible to have your old one rebuilt. Keep us posted of your progress.....Bill
https://bpi.ebasicpower.com/charge/alternatorwiring.htm
John; Thought it might help if I posted the ABYC codes for wiring. Might help out in your finding a solution.
I've been going off page 31 in the Manual. https://www.catalina36.org/sites/default/files/legacy/M25_Workshop_Manual.pdf
Hummina
#741
The purple comes from the alternator and goes to the key switch. At least that is how I've wired it.
A Gentleman on the Diesel Boat Engine Facebook page has given me a schematic that solved his same problem. Thoughts?
Hummina
#741
